FS: TPA3116 YJ Amp modified by RHing - SOLD
0 Members and 1 Guest are viewing this topic. Read 1444 times.
shadowlight
« on: 30 Mar 2016, 12:04 am »
For sale is a TPA3116 YJ amp which I had RHing build for me.  It also comes with Lenovo/IBM power supply which works well with the amp.  Looking for 150 shipped and no paypal fees.  You are welcome to pick it up if local to 08540
Yuan Jing TPA3116 Class-D 2.0 Stereo Amplifier Board [50W+50W]
Panasonic Aluminum Electrolytic Capacitors - Leaded 1500UF 25V ELECT FM RADIAL
Wima MKP10 Film Capacitors 250V 1uF 5% PCM 22.5 11X21X26.5
Keystone Electronics 4109 Test Plugs & Test Jacks BINDING POST
Switchcraft DC Power Connectors 2.0MM round w/ nut
RCA Phono Connectors RCA PANEL JACK GOLD/WHITE REAN
RCA Phono Connectors RCA PANEL JACK GOLD/RED REAN
Panasonic POT 50K OHM 12MM VERT MET BUSHING
Bourns Fixed Inductors TOROID INDUCTOR 10uH HI TEMP VERTCL MT
Context Engineering 6.0" L x 4.13 W x 2.47" H Split Body Aluminum Enclosure
NKK Switch SWITCH TOGGLE SPST 10A 125V
Kilo International KNOB CLR MATTE.925"DIA 6MM SHAFT
« Last Edit: 19 Apr 2016, 11:11 pm by shadowlight »
wushuliu
Re: FS: TPA3116 YJ Amp modified by RHing
« Reply #1 on: 30 Mar 2016, 06:39 pm »
Nice, clean build. Jealous. It'll go fast.
shadowlight
« Reply #2 on: 31 Mar 2016, 12:25 am »
Yep, it is a clean build.  I just have way to many tpa amps (two DUG board that I still need to finish and 2 of the Wiener boards from the Diyaudio group buy).  This one is the one that is in the best shape build and quality wise  :thumb:
shadowlight
« Reply #3 on: 14 Apr 2016, 07:32 pm »
Bump
