Just bought a new VPI Scout
0 Members and 1 Guest are viewing this topic. Read 3833 times.
Nick77
« on: 27 Mar 2016, 06:55 pm »
Well new to me that is.  :wink:
Blows away my vintage Sony table. I am getting some noise out phono preamp at about 1 oclock, would the Denon 103r be considered a noisy cartridge? My preamp has pretty low distortion levels so wondering if its the cart??
S Clark
Re: Just bought a new VPI Scout
« Reply #1 on: 27 Mar 2016, 07:30 pm »
Did you mount the cartridge?  If not, check it.  The output of the 103r is pretty low- which pre are you using? Does it have enough gain?
Nick77
« Reply #2 on: 27 Mar 2016, 07:37 pm »
Yes Sir I mounted the cart using a Willis protractor for Baerweld alignment. I have the VTF set slightly high as reccomended by VPI. Azimuth is set perfect and VTA looks good.The phono pre is an obscure beast I grabbed on a whim but sounds really good. It has amazing distortion specs, but alas real world is sometimes different matter. It costs some 700 euro. Its powered by a walwart, I wonder if thats an issue? It has 67db gain.
http://www.holographicaudio.com/riaa.html
Edit: Sounding much better on an Analog Productions 200g album, might have been noisy vinyl??
Grbluen
« Reply #3 on: 28 Mar 2016, 01:00 am »
Congrats on your Scout! I've run one for about 15 years. It's a great table.
rif
  • Not a cowboy
« Reply #4 on: 28 Mar 2016, 01:06 am »
Are you sure it's the phono preamp? If you're concerned about the wall wart, if the voltage is low enough perhaps try jury rigging a battery supply.  It probably draws a really small current, see what the mfg states.
Edit: I'm assuming no tubes.
VPI makes some great tables and they're a great company too.
« Last Edit: 28 Mar 2016, 12:39 pm by rif »
« Reply #5 on: 28 Mar 2016, 02:47 am »
Nice looking acquisition Nick  :thumb: Keep 'em spinnin'  8)
S Clark
« Reply #6 on: 28 Mar 2016, 03:49 am »
Was the problem the LP?
mav52
« Reply #7 on: 28 Mar 2016, 11:59 am »
What kind of noise is it ?
What is your tracking force ?
 That cartridge is on the warm side , not bright
I also use a Ken Willis Accutrak protractor for my Classic with a 10.5i arm along with a Dynavector DV-20x2L feed into a Manley Phono Amp.
Nick77
« Reply #8 on: 28 Mar 2016, 12:55 pm »
Thanks for the feedback, I need to do some more listening as it seemed all was well with different vinyl. I didnt even suspect vinyl being the issue cause its a brand new 180g album.  :duh:
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #9 on: 28 Mar 2016, 03:28 pm »
Good sleuthing S.Clark!
Best,
Anand.
mav52
« Reply #10 on: 28 Mar 2016, 03:34 pm »
Lets us know what your hearing and check your tracking force.   If I had to pin any issues, I would say phonostage since it appears that stage you have doesn't have any loading for impedence.
That denon likes  2.5 grams for tracking force and also a 100 ohm impedance setting or a little more.
Nick77
« Reply #11 on: 1 Apr 2016, 09:46 pm »
It was definitely the vinyl, what a relief. This album went back but didnt have another copy. Ordered online for $10 cheaper, hoping for the best. Its a great album. http://www.musicdirect.com/p-393196-avishai-cohen-into-the-silence-180g-vinyl-2lp.aspx
S Clark
« Reply #12 on: 1 Apr 2016, 10:48 pm »
Good.  When you step up on the vinyl carousel you don't want to take a step backward, and the Scout should be a nice step up.  One of these days I've got to make a trip to Austin to hear your rig.  I've got a Chinese motor coming for my Vyger, and just built a mount for an arm for it.  Hopefully it will be a step up from a JVC QL-F6... just have to wait and see.
