Jriver + Gizmo app = goodbye HDMI handshake issues
0 Members and 1 Guest are viewing this topic. Read 1099 times.
windhoek
  • Live life like you're gonna die, cos you're gonna!
« on: 27 Mar 2016, 10:43 am »
I finally solved the HDMI handshake issues I've been frustrated with when using Jriver via HDMI to my AVR. Admittedly it's more of a work around than a solution per se, but it works nonetheless.
Playing music via HDMI works fine until the TV is turned off, whereupon playback stutters for a few seconds before resuming, and the same goes when the TV is turned on during playback. I used to turn off my TV's display to negate this issue (the TV would still be on), thereby ensuring the handshake remained active, but my new TV has the Display Off option buried deep within its settings menu, which is somewhat inconvenient when I simply want to press Play and listen to music.
The solution I stumbled upon last night however, is to set Jriver to launch on computer start up and use Jriver's Gizmo Android app to navigate within Jriver and control playback ... without even turning on the TV once. It's that simple.
My mac mini (running Windows 7 thanks to Bootcamp) is a dedicated HTPC and all it does is play music, so unless I'm ripping new music or want to watch visual content, there's no need to turn on my TV. For extra convenience, I've set it to hibernate/resume when the power button is pressed.
Although I'd still like future AVRs to support multichannel audio via async USB, there's nothing to indicate that's going to happen anytime soon, so this solution will tide me over until than and hopefully you too if you're in a similar situation :)
Derek
