Remote On/Off Codes - BDA-1 and BDP-2 (BDP bug)
0 Members and 1 Guest are viewing this topic. Read 2406 times.
adprom
« on: 26 Mar 2016, 02:44 am »
There appears to be a bug that the BDP-2 erroneously uses the same code as the BDA-1 for on/off and not the code it is supposed to use. This is quite frustrating since when trying to use these devices with a universal remote control, you cannot independently power them and they become out of sync (in this case with a Logitech remote control).
The BDP-2 really needs to use its own discrete remote control code.
guyguay
Re: Remote On/Off Codes - BDA-1 and BDP-2 (BDP bug)
« Reply #1 on: 26 Mar 2016, 11:40 am »
Both BDA-2 and BDA-3 have the Same Codes (ON/OFF) same as the BDP-2
I talked to Mike Pickett for this issue and he said that is set for The BR-2 Remote
I use a Universal remote with HEX CODES and i have the same problem
Martin
Ritchief
« Reply #2 on: 26 Mar 2016, 12:35 pm »
Guyguay, try this HEX code:
0000 006D 0000 0012 0049 000B 000B 0049 000B 0049 000B 0049 0049 000B 0049 000B 000B 0049 0049 000B 000B 0049 000B 0049 0049 000B 000B 0049 0049 000B 0049 000B 0049 000B 000B 0049 000B 0049 000B 0298
guyguay
« Reply #3 on: 26 Mar 2016, 02:44 pm »
What this code is for
BDP-2 or BDA-2
And is this the On or OFF code
Look At the Codes i have
OFF
bcd-1        0000 006D 0000 0012 0049 000B 000B 0049 000B 0049 0049 000B 000B 0049 0049 000B 000B 0049 0049 000B 000B 0049 000B 0049 000B 0049 000B 0049 000B 0049 000B 0049 000B 0049 0049 000B 000B 0049 000B 0298
bda-2        0000 006D 0000 0012 0049 000B 000B 0049 000B 0049 000B 0049 0049 000B 0049 000B 000B 0049 0049 000B 000B 0049 000B 0049 000B 0049 000B 0049 000B 0049 000B 0049 000B 0049 0049 000B 000B 0049 000B 0298
bda-3        0000 006D 0000 0012 0049 000B 000B 0049 000B 0049 000B 0049 0049 000B 0049 000B 000B 0049 0049 000B 000B 0049 000B 0049 000B 0049 000B 0049 000B 0049 000B 0049 000B 0049 0049 000B 000B 0049 000B 0298
bdp-2        0000 006D 0000 0012 0049 000B 000B 0049 000B 0049 000B 0049 0049 000B 0049 000B 000B 0049 0049 000B 000B 0049 000B 0049 000B 0049 000B 0049 000B 0049 000B 0049 000B 0049 0049 000B 000B 0049 000B 0298
ON
bcd-1          0000 006D 0000 0012 0049 000B 000B 0049 000B 0049 0049 000B 000B 0049 0049 000B 000B 0049 0049 000B 000B 0049 000B 0049 0049 000B 0049 000B 0049 000B 0049 000B 0049 000B 000B 0049 000B 0049 000B 0298
bda-2          0000 006D 0000 0012 0049 000B 000B 0049 000B 0049 000B 0049 0049 000B 0049 000B 000B 0049 0049 000B 000B 0049 000B 0049 0049 000B 0049 000B 0049 000B 0049 000B 0049 000B 000B 0049 000B 0049 000B 0298
bda-3          0000 006D 0000 0012 0049 000B 000B 0049 000B 0049 000B 0049 0049 000B 0049 000B 000B 0049 0049 000B 000B 0049 000B 0049 0049 000B 0049 000B 0049 000B 0049 000B 0049 000B 000B 0049 000B 0049 000B 0298
bdp-2          0000 006D 0000 0012 0049 000B 000B 0049 000B 0049 000B 0049 0049 000B 0049 000B 000B 0049 0049 000B 000B 0049 000B 0049 0049 000B 0049 000B 0049 000B 0049 000B 0049 000B 000B 0049 000B 0049 000B 0298
BCD-1 BDP-2 BDA-2 BDA-3 Have the Same ON/OFF codes
Martin
adprom
« Reply #4 on: 27 Mar 2016, 01:18 am »
It is not supposed to though.
The logitech database actually has an entirely different on/off code for the bdp-2. However, it does not work.
It is almost like after the fact, bryston changed the bdp-2 code to be the same as the others.
There is absolutely no reason that different classes of devices (CD/DAC/Dig Player) should share any of the same codes.
guyguay
« Reply #5 on: 27 Mar 2016, 01:54 pm »
This Code is an ON/OFF code (TOGGLE)
IT'S THE code For BDA-2 BDA-3 BDP-2
Bryston should fixe those codes
