**SOLD**DMN Solid Core Stereo Speaker Cable 10'**SOLD*
0 Members and 1 Guest are viewing this topic. Read 957 times.
rodge827
DNM Solid Core Stereo Speaker Cable 10' for sale.
This is an awesome cable that punches way above its cost. I have used various DNM cables for many years and were the end of my cable search. Sadly though I'm selling all of my gear due to losing my listening room, and going to head phones.
From the DNM Website:
Designed for use with normal-to-low sensitivity loudspeakers DNM Stereo matches the audio performance of DNM Precision 2 but it can be used with larger audio systems, longer cable runs, speaker sensitivity below 89dB/watt and more powerful amplifiers.
The ribbon dimensions are set to reduce the capacitance and slightly increase the inductance, to ensure amplifier stability with longer runs of cable. The result is a stereo ribbon 25.5mm wide and 2.7mm thick with the same facility for easy installation as the Precision cable but with a much higher performance in medium to low sensitivity speaker systems.
The DNM Stereo ribbon is 25.7mm wide x 2.7mm thick and it contains four 1.3mm diameter high purity copper conductors. A single length of DNM Resolution connects two stereo speakers or one bi-wired speaker. Easy-separation lines in the ribbon make cable preparation very easy.
The unique design of the DNM ribbon places the conductors above the ribbon's centre-line to project the magnetic field through air rather than insulation. The cable's structural Q is low because the easy-separation lines also reduce the ribbon's stiffness.
Visually DNM Stereo is equally advanced, with a semi-transparent outer ribbon and coloured insulation on the conductors.
The electrical parameters of DNM Stereo, its capacitance, inductance and resistance, are aligned to improve the driving amplifier's stability and sound quality.
MSRP $248.00 + Shipping
Asking $135.00 PayPal and Shipping Included To Lower 48
Located 08087
Local Pickup OK, Cash, Check (ship when clears), PayPal, PMO
« Last Edit: 30 Mar 2016, 05:23 pm by rodge827 »
rodge827
Re: FS: DMN Solid Core Stereo Speaker Cable 10'
« Reply #1 on: 24 Mar 2016, 09:23 pm »
Bump
Make an offer for this great speaker wire  :D
md92468
« Reply #2 on: 28 Mar 2016, 08:37 pm »
Hello – I sent you a PM a couple of days ago with an offer. Please let me know if the cable is still available. Thanks!
Matt
rodge827
« Reply #3 on: 30 Mar 2016, 02:17 pm »
Matt,
You have a PM.
Chris
