Integrated
0 Members and 1 Guest are viewing this topic. Read 2253 times.
OBF
Integrated
« on: 28 Oct 2004, 11:49 pm »
I've been thinking of picking up a used integrated to use while getting my preamp upgraded and then possibly keeping it for a 2nd system if I like it.  Like everyone I want transparency, but tending toward warmth would be my preference since I think the 1801 monitors can use a bit.  I don't want to spend much more than $1,000 and I've been thinking about a Plinius 8200 MkI and Sim I-3.  The Plinius has more power and a phono pre (which is unlikely to be used but handy just in case).  Oh yeah, a remote is a must so most of the tube integrateds are out because of this, but I'm sure there's a few contenders.  The Perreaux 200i is interesting, but I doubt I'd find one in a similar price range compared to the others on my list as they seem fairly rare.  Any suggestions would be appreciated.
vpolineni
Integrated
« Reply #1 on: 28 Oct 2004, 11:51 pm »
you may want to consider a blue circle integrated amp.
OBF
Integrated
« Reply #2 on: 29 Oct 2004, 12:13 am »
I didn't think they had remotes on any of their models.  Been a while since I looked though.
PhilNYC
Integrated
« Reply #3 on: 29 Oct 2004, 01:14 am »
Quote from: OBF
The Blue Circle CS Integrated has an optional remote volume control which can be added for $250.
Integrated
« Reply #4 on: 30 Oct 2004, 12:39 pm »
Tough price range (at least for new/retail).  Things get much more interesting at $1200 - 2000.
Remote control requirement is another real limiting factor.  The Cayin TA-30 (30 wpc EL34 tubes) is wonderful.
I'm auditioning a JVC RX-ES1SL (100 wpc digital/hybrid HT receiver that retails for $300).  In terms of sound quality and features it kicks the butt of my 6 year old Rotel.  And of course it has a remote.  Naturally build quality doesn't approach the Rotel.  Again, makes for a tough price range IMO.
mca
Integrated
« Reply #5 on: 30 Oct 2004, 04:56 pm »
How about the Unison Research Unico? It has a remote and tubes in a hybrid design. Plenty of power and a bit of warmth also.
Hantra
Integrated
« Reply #6 on: 30 Oct 2004, 07:11 pm »
I'll second the BC recommendation.  Fantastic piece, and probably the best at that price.
OBF
Integrated
« Reply #7 on: 31 Oct 2004, 01:15 am »
Quote from: JLM
For the most part I prefer to buy used and there seems to be a fair amount of $2k-$3k list units in the $1,000-$1,200 range, like the Plinius 8200.  The remote does eliminate a lot of good ones, but since this is for a system that will involve family members and video, it's a must.
Quote from: Hantra
Thanks.  If I don't get something now I'll keep an eye out for one.
  • Speakers....What Speakers ?
Integrated
« Reply #8 on: 31 Oct 2004, 01:26 am »
    http://cls.audiogon.com/cgi-bin/cls.pl?intatran&1103297771 [/list:u]
    OBF
    Integrated
    « Reply #9 on: 31 Oct 2004, 02:19 am »
    Quote from: lonewolfny42
      I'd have to stretch with the remote option added in and now that I see it's 50 watts, I'm not sure that would be ideal for 1801s.  Something to consider though.
      tvyankee
      Integrated
      « Reply #10 on: 31 Oct 2004, 02:32 am »
      hello.
      you might want to check this out.
      i know these guys make go stuff.
      http://audioadvisor.com/store/productdetail.asp?sku=DMCR5350SE
