0 Members and 1 Guest are viewing this topic. Read 9911 times.
I've heard the B6, a nice modern (constipated light weight bass, spritely voicing) passive monitor. I expect the B5 to have even less bass. (This from an owner of single driver speakers.) OTOH the Yamaha NX-N500 scare me from their NS-10 vintage (which was popular in studios, but mostly because it emulated typical/horrible consumer speakers). It seems very well equipped, but possible of the fast moving technology I'm not a fan of speakers with built-in DAC. Plus having so many possible connections and built-in DAC smells of a consumer product, while most active monitors are intended for studio work and I'd expect better made. Note the poor reliability was one of the downfalls of the Paradigm Active 20's/40's from years ago. In execution they totally kicked butt of their passive counterparts.Being a single driver speaker owner, I'm a fan of active speakers (as single drivers are by default). But I'd look at Audiostream.com for consumer oriented active monitors (something like Adam F5) and use your Modi 2 Uber (better yet a BiFrost and go to Blue Jean Cables for your wiring).
Im not sure what you mean by single driver speakers are active by default. I cant even think of one that is.
Most are. The amplifier (whether internal or external) is wired directly to the driver with no passive crossover network in between.Steve
JLM no offence intended but you're into digital and high endfull range drivers are a compromiseyet you go for ityet you know alot of speakers and room's acousticsi don't get it?,are you into high end or not?cheers...
Sorry to confuse. Yes, single driver speaker owners do get to pick their amp. And many pick tube amps (which is all but impossible to find built into a "true" active speaker. Note that there are a very few active speakers that have externally mounted amps (to allow for use of physically bigger amps and smaller or specially shaped speakers like the Munro Egg 150). Active designs can be had for relatively cheap. For instance the JBL LSR305 is a reasonably well respected active 2-way with 5 inch woofer that sells for $300/pair and are rated down to 41 Hz. I'd say impossible to find decent passives with that performance, including the necessary amp.Active designs allow for a very direct connection between amp and driver. And the crossover are low voltage designs that can be much more sophisticated. (For instance the crossover in the $400/pair concentric Equator D5 are each factory tweaked with built-in DSP to provide highly matched pairs before shipping.) This produces markedly improved dynamics, flatter frequency response (a revelation in itself), and almost greatly extended/increased bass response compared to comparable passive speakers.The real challenge of finding active speakers for home use is the fact that most are designed for studio work so they have a dry/analytical presentation that can be fatiguing. Make no mistake, active studio monitors typically are very accurate, to get to the correct mix as quickly as possible. But audiophiles want to be entertained and their fancies to be tickled (variations of euphoria, which explains why so many different home speakers are in the market). So as always, listen for yourself.
wprking on it. why doesnt the forum auro resize like other forums? you know, make a small preview and go to full size when clicked.
It DOES!!!If you actually upload them to the forum, that is.If you just put them somewhere else, and then expect magic - well I guess that doesn't work.
