SP2 custom power cable *problem* with fuse box
0 Members and 1 Guest are viewing this topic. Read 791 times.
derekcooper
« on: 3 Mar 2016, 04:44 pm »
Hey Brystoners,
I've been upgrading power cables for my gear, but ran into an interesting *issue* yesterday - the fuse box on the SP2 projects out from the rear of the unit directly above the plug. If you're using Oyaide / Furutech / etc plugs, they actually won't fully insert as a result.
Any solutions / ideas?
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP2 custom power cable *problem* with fuse box
« Reply #1 on: 3 Mar 2016, 04:54 pm »
Hey Brystoners,
Gee I am sorry I do not have any suggestions as you can not remove the fuse holder.
james
derekcooper
« Reply #2 on: 3 Mar 2016, 04:55 pm »
I was like - *DOH* - that's a little odd of Bryston!!! LOL
