Which Room to choose!
0 Members and 1 Guest are viewing this topic. Read 9380 times.
Sonny
« on: 27 Feb 2016, 11:07 pm »
All,
So, here's the question, which would you rather take as a listening room and why?
One that is 14x19x8 feet (WxLxH) or one that is 14x15x9?
Longer room has window on the short wall end, about 70"x46" the shorter room has a side window on one side of the 15' wall, about same size window.
Simple question, no?
timind
  • permanent vacation
Re: Which Room to choose!
« Reply #1 on: 27 Feb 2016, 11:25 pm »
If I had complete freedom to make the room dedicated to audio and nothing else, I'd go with the 14x15 room. Yeah, it's nearly square, but I like the 9 ft ceiling. I have my system in a near perfect square room and am hearing the best sound I've heard in any of my rooms.
Good sound is easy with the speakers setup in a diagonal configuration. I got the from the Decware site and damned if it doesn't work wonders.
Sonny
« Reply #2 on: 27 Feb 2016, 11:29 pm »
Thanks Timind for the response.  I like those Kestrels!
Yes, this is going to be "MY" room, either one.  I do like the 9th ceiling, like the rectangular room for some reason, feels bigger.  We it is bigger.  Also never like the "diagonal" set up for some reason. :scratch:
ACHiPo
« Reply #3 on: 27 Feb 2016, 11:32 pm »
I tend to agree with Timind.  My listening room is similar (15.5 x 17.5 x 9), but with lots of coves, etc.  I definitely like the higher ceiling.  The nearly square geometry can be dealt with fairly well with acoustic treatments (I have bass traps around the wall/ceiling perimeter).
Sonny
« Reply #4 on: 27 Feb 2016, 11:41 pm »
What about treating the ceiling with some diffusion or absorption?
timind
« Reply #5 on: 27 Feb 2016, 11:53 pm »
The diagonal set up does seem to limit the room's other uses as it really focuses the listener to be centered in the opposite corner. That being said, I have my chair centered and a nice love seat next to it on the wall.
If you have the chance though, you really should give it a try before you decide. Other than bass traps which are going in corners anyway, you can try it before permanently placing other treatments.
max190
« Reply #6 on: 28 Feb 2016, 12:07 am »
What spkrs are going in this room?
Sonny
« Reply #7 on: 28 Feb 2016, 12:09 am »
I will also be using some subs, seen at the left of the left speaker. I have two of those...to help 30hz and below.
Speakers and subs are sealed, not ported.
« Reply #8 on: 28 Feb 2016, 01:05 pm »
If you read Cardas site or Floyd E. Toole's "Sound Reproduction" you'll choose the longer one which is ideal for breaking up echo.
I tried the Decware skewed setup, but when I read it I gathered that he was recommending a non-symmetrical layout and even in a longer room did seem to help a bit.
I followed Cardas and built his "Golden Cuboid" (the ancient Greek Golden rectangle): 8ft x 13ft x 21ft.  Love it with near-field setup and 25 - 20,000 Hz speakers (GIK panels are almost useless).
BTW trying to tame bass with treatments is extremely difficult.
max190
« Reply #9 on: 28 Feb 2016, 01:26 pm »
I agree with JLM that you should choose the longer room, but I have to disagree that trying to tame bass is extremely difficult.
Also, I hope you are not putting that TV back on the front wall.
Letitroll98
  • Too loud is just right
« Reply #10 on: 28 Feb 2016, 03:04 pm »
All things being equal, another vote for the longer room.  I like 9'ceilings as well, but in this case it just makes it closer to a cube.  You have a near perfect room size, why not use it.  However, I have the same choice coming up and I'm picking the square'ish room for audio.  Because the alternate room must be a bedroom and I want the larger room with the attached bath and fancy closet for the bedroom.
ACHiPo
« Reply #11 on: 28 Feb 2016, 04:49 pm »
Ceiling "clouds" are definitely an option, but with an 8' ceiling height things could start feeling a bit claustrophobic if you add a few inches of absorption + gap.
« Reply #12 on: 28 Feb 2016, 04:59 pm »
All,
Bigger is better, 14x19x8 are bigger, roof too low otherwise looks great.
Read Small Room Club:
http://www.audiocircle.com/index.php?topic=107352.msg1183456#msg1183456
Rocket_Ronny
    • ScriptureSongs.com
« Reply #13 on: 28 Feb 2016, 07:16 pm »
Bigger room almost always. I would pull them about 9' into the room and about 1.5' from side walls and sit close to the wall with a pillow behind my head to stop reflections.
I am not a fan of speakers at a 45% to a corner as i hear the soundstage depth diminish the farther away you go from the corner. Now if you heavily damped the wall that would really help.
Rocket Ronny
youngho
« Reply #14 on: 28 Feb 2016, 08:10 pm »
Is the window in the 8x14x19 room centered in terms of the wall?
Also, are those your Audio Kinesis Jazz Modules in the uploaded pictures in your gallery?
Sonny
« Reply #15 on: 28 Feb 2016, 10:11 pm »
Yes, the window is dead center.  Probably will be the front wall, behind the speakers.
I am leaning towards the larger room.  Plan to dampen the ceiling, first reflections on the side walls as well.  Will sit near field, maybe 9 ft triangle, set up.
Tuan
Sonny
« Reply #16 on: 28 Feb 2016, 11:33 pm »
Max, no, this is strictly MY room, so no TV....:)
youngho
« Reply #17 on: 29 Feb 2016, 01:34 am »
Tuan
An open window is essentially a perfect absorber, but you'll want to have some sort of absorption over the unopened portion (or the entirety when closed), whether it's a multilayer (double cell or more) cellular shade or velour or velvet curtains.
Great, that room might be more likely to give smoother bass. 9 ft is probably more than near field? Consider some diffusion centrally behind the listening position, also maybe on the rearmost portion of the side walls? Use thicker (3-4") absorption for the frontal reflection points if possible.
Young-Ho
Folsom
« Reply #18 on: 29 Feb 2016, 01:38 am »
I like a window...
max190
« Reply #19 on: 29 Feb 2016, 11:35 pm »
I'm proud of ya  :)  But now you have to deal with that window.  Young-Ho has some good ideas for covering it, and you could open it as that will act as a bass trap.  Nice system you have there.
