0 Members and 1 Guest are viewing this topic. Read 9355 times.
GR Research X-LS Classic Kit - $109/pair Includes:2 - woofers2 - soft dome tweeters2 - assembled crossovers2 - input cups, port tubes, wire & mounting screws
specifically this tweeterTymphany XT25SC90-04 and then I am not sure what to pair it with.A good question would be what benefits come from running at 8ohms instead of 4 likfe would be the case if i went with the vifa
You do understand that designing a correct crossover for your drivers is over the heads of nearly every DIY right? You need very expensive specialized measuring equipment along with a serious amount of crossover design knowledge to even half correctly design one. With the above suggestions above you get an extremely well designed speaker that easily competes with 4 figure speakers at a bottom end price point. I'm also a very happy GR-Research customer and own many speakers from them.I've also heard the XT25 tweeter you mention above, as I had it in a previous speaker. It's good, but not as good as the Peerless T26SG in the x-ls encore mentioned above which I have in my current speakers.
+1 on the X-LS.
+2...
what about a set of polk audio t50's? for 150 and I would not have to make a box so that puts me right around my budget. Would I even have enough power for them with a 3116 at 13.8 watts?
I'm just wonder what are some good ones for under $100 for 2 tweeters and 2 mids
