Advice for Model T amplification
0 Members and 1 Guest are viewing this topic. Read 1208 times.
Yitshak
« on: 24 Feb 2016, 10:33 am »
Hi James and everyone,
Looking for some knowledgable advice regarding Model T amplification requirements,
For one like me that like big sound.
Will one 4B sst2 can provide enough grunt and headroom to power the above
In room size say 19.5' X 13' X 8.4'   (9.6' between speakers) ?
If I join my second 4b sst2 that I already have in vertical bi amp will that contribute noticble
Improvement ?
Later on its look the correct path will be to add 7b3's eventually
but it can't be both at the same time,and I don't know how long.
Most of my listening habits
Big sound with lots of details:
Classical: Late Baroque/Classic/Romantic era symphonies and big orchestral works.
Jazz:60'-70' big bands
Then some
Rock blues/country/ prog: metal/rock
Mini Ts provide the stage for know and I'm happy with them like never before.
I'll Apriciate your thought and advice
Yitshak
  • The Demo is Everything!
    • http://www.bryston.com
Re: Advice for Model T amplification
« Reply #1 on: 24 Feb 2016, 03:16 pm »
Hi Yitshak
The Model T is relatively efficient at 89dB - 3dB more than your Mini T.
So If you are getting good volume levels with no clipping on your 4B then you would be fine with Model T's.
james
Yitshak
« Reply #2 on: 24 Feb 2016, 04:02 pm »
Hi Yitshak
james
Thanks James
I thought so from earlier posts I saw but wanted to make sure
And hear from more experienced.
I don't get clipping with the Mini T's and they rumble as high as I like
So a 4b sst2 can hold it at my reasonable hearing levels.
So an extra 4b sst2 is not something of need.
That's real help as I can keep my second system running in that period
Which is very important for me.
But to clarify for myself:
by adding one more 4b sst2 does it provide any extra at all or could it result
In degrading SQ do to some reasons I'm not aware?
Yitshak
« Reply #3 on: 24 Feb 2016, 04:26 pm »
Thanks James
Yitshak
Hi
Because you are going through the crossover the second 4B does not really provide any advantage.
James
Yitshak
« Reply #4 on: 24 Feb 2016, 05:40 pm »
Thanks James,
it's simplified my considerations for later on.
Yitshak
