0 Members and 1 Guest are viewing this topic. Read 18812 times.
Prometheus TVC? Transcendent Ground Grid?Or am I better off spending a little more on an integrated amp like the Rogue Sphinx / Naim Nait 5SI?
The Crown input sensitivity is 1.4v.Full specs here, as well as the link to the current model, the 1502.http://www.parts-express.com/crown-xls-1500-power-amplifier-2-x-525w-at-4-ohms--245-502
Crosstalk: @ 1 kHz >85 dB; @ 20 kHz >55 dB
My amp doesn't have great crosstalk specs, nor does XLS. You could never tell by ear with either. I don't think it's the most interesting value to look at. It just doesn't correlate well with what you'll hear.
Do you presently own the XLS amp?
...would you be planning to use it for a PA system?
If used for a home stereo system, it may not have the fidelity you desire.
