0 Members and 1 Guest are viewing this topic. Read 8795 times.
Mike - check that your phono ground wire didn't come loose. Scott
Rumble can also be transmitted via the drive belt to the platter from the motor.
I bought the predecessor of your table (The Genie 3 ??) -looks pretty much the same -mine had been a severally abused store demo. I've been workin on tables for decades and after about 10 hours into "fixin"this one decided to set it aside for a future effort (maybe never). The motor seems to be the issue - I kept doing circular e-mails with Europe to ca. to mn . e-mail strings trying to get parts and service info. This thing thumps -well above simply rumble levels -unless you cushion the motor pod with something like room temperature freeze packs .That worked (sorta) except that the motor pod had to be outside the ring (NBD) and the location wasn't stable enough -so bass thumping got traded for higher pitched flutter problems. Please understand this is not a slam on Pro-Ject tables ( I have almost no experience with them) - but this one did what the OP is describing.
Rumble comes from the bearings, either platter or tonearm, or the cartridge suspension. I couldn't imagine the bearings going bad since Christmas, do you have another cartridge to try? Is it rumble or hum?
It helped some. The excessive over extension of the drivers is not occurring at normal listening levels but increases as the volume is turned up. At high volumes the cone movement is so bad it literally vibrates the Wedgies (midrange/tweeter modules) off the top of the subs.Unfortunately, no. The only cartridge I have is the one that came with the TTMike
