0 Members and 1 Guest are viewing this topic. Read 4334 times.
You can't get HD from DVD. DVD only has 540 lines or so of resolution, so that is all that is possible. What the direct digital connection can do is provide the latest conversion processing (in the new DVD player) and get that signal to your TV in it's native resolution. That gets you a better picture as you have indicated, so that's a good thing. There will be HDDVD at some point, pehaps in two years for most of us, but it will be a different format which will require a new HDDVD player to get that resolut ...
Hi Byteme,(It is byteme, right?!) Yeah, that's clear as mud. I don't put any credence in reviews, but my own evaluations. I would not discount the posibility that it will handily outperform your player with it's component outputs. I would however be completely guessing if I were to place a bet on the outcome either way. It's a cool idea to eliminate the cable losses and get the latest digital conversion by using a new, outboard converter at the source. But the proof is in the pudding and the real issue is ...
