Steps on how to use Analog Production Test LP
0 Members and 1 Guest are viewing this topic. Read 1266 times.
S1NN3R
« on: 17 Feb 2016, 02:02 am »
Is there any Youtube video showing steps on how to properly use Analog Production Test LP?
neobop
  • BIRD LIVES
Re: Steps on how to use Analog Production Test LP
« Reply #1 on: 17 Feb 2016, 03:57 am »
Hi,
I don't think so.  Basic instructions are on the back cover.  You need test equipment for azimuth.  Check this out:
http://www.theabsolutesound.com/articles/setting-up-a-phono-cartridge-1/?page=4
Azimuth matters and you're more likely to need adjustment with a hand built cart.  It's a misconception that azimuth depends on the tip being perfectly vertical (side to side) in-groove.  It's the coils or armature that must be parallel to the record surface which is more likely (I think) in a mass produced cart.
Anyway, if you don't have Feikert software, you can get pretty close with a decent output display, but it's a little tricky to get it perfect.  You'll have to fine tune by ear.  When you get it real close you'll hear it.
neo
londonbarn
« Reply #2 on: 17 Feb 2016, 07:37 am »
Shoot Chad an email and ask him.. I am sure someone at AP would be happy to help...
S1NN3R
« Reply #3 on: 18 Feb 2016, 01:06 am »
Thank you Neobop and Londonbarn.
I think Analog Production should make a video of it to boost sales.
