0 Members and 1 Guest are viewing this topic. Read 6857 times.
This might help.http://www.decware.com/paper43.htm
Hi HiFiJeff,I have a Decware SE84C+ with a pair of Omega 7F in a open baffle dipole configuration,(Only a few were sold like that bu Louis, meaning without enclosure, just driver)and it's the best sounding audio set up I've owned.May I recommend, it not really required, but...a Decware ZSTAGE pre-amplifier, it helps for the dynamicswith sources that have less than 2Volts.Guy 13
I like Steve Deckert and his products. The sound of his SE84 is clean and clear. The hallmark of the amp for me was it's 3D imaging. It was as good as a Sun 300B I once owned and yet more involving. Since it likes a low impedance load it performed much better when used with some autoformers to lower the imdedance of the fostex full range speakers. I found the top and bottom end to be slightly soft when comparing to other tube amps, but none would outperform the imaging the SE84 offers. I had plans to buy one and even pre purchased a bunch of SV83/6P15P-EV tubes, still have them somewhere and need to get rid of them, but ultimately needed more power. You should enjoy the amp. Rocket_Ronny
I can Second the comments from Rob & seikosha,With speakers as revealing as the Omegas and a decent source I can hear a slight (but noticeable) reduction in sound quality when I install my Decware pre-amp between my Oppo player and Zen UFO. Needless to say my Decware pre-amp does not get a lot of use. Adding the pre-amp gives the music a slightly Darker Tone which some may interpret as more weight. But overall the pre-amp does more harm than good in my system.
My first Oppo was the BDP-83 Special Edition with upgraded analog output. I upgraded to the BDP-105D shortly after it came out. I do prefer the 105 to the 83 but the older 83 & 95 models are still very good players and can be had pretty cheap used.Even though my audio system is only 2-channel, I use it for Home Theater purposes also. A killer 2-channel system is no slouch at HT. So I need a quality Blue Ray player for HT and a quality source for music listening. For me the Oppo is a quality one box solution for both purposes.
