FS: SOLD Lighter Note LDR Volume Control / Preamp
0 Members and 1 Guest are viewing this topic. Read 1827 times.
RickRichardson
SOLD
This Lighter Note LDR volume control/preamp uses Light Dependent Resistors (LDR's) to control the volume level.  This approach is intended to do away with switch contacts and wipers, to give a cleaner, smoother control of volume.  The Lightspeed Attenuator designed by George Stantscheff has been highly touted, and the Lighter Note LDR was developed by Uriah Dailey to be an improvement over that earlier design.  The Lighter Note includes a high-quality power supply, high-value by-pass resistors and circuitry to vary total attenuator resistance.
This unit has one set of inputs and one set of outputs, plus a channel balance control.  I was told this unit was built by Don at Abacus Music using the board developed by Uriah Dailey.  It is a very clean, professional build.
I found this Lighter Note LDR volume control to be a more open and transparent than the Lightspeed Attenuator. It also allows for adjusting the balance with a knob on the back, rather than having to take the case apart and tweak a very small screw on the board inside.  If you are looking for a volume control/preamp that “gets out of the way”, this is it.
I am looking for $250 plus shipping paid via Paypal. The shipping package will be 6 lbs.
« Last Edit: 22 Feb 2016, 07:17 am by RickRichardson »
ClefChef
Re: FS: Lighter Note LDR Volume Control / Preamp
« Reply #1 on: 16 Feb 2016, 03:40 pm »
This is Uriah Dailey's design and it is excellent  :thumb:
RickRichardson
« Reply #2 on: 17 Feb 2016, 05:49 pm »
Sorry for the misspellling!  Dailey is correct, and yes it sounds great, that is it sounds like nothing.
srosenberg
« Reply #3 on: 20 Feb 2016, 07:57 pm »
is this unit still available?  i've sent two PM's, both unanswered.
RickRichardson
« Reply #4 on: 20 Feb 2016, 09:46 pm »
Sorry for the delay.  I have responded to your PM.  I need you zip code to figure the shipping.
RickRichardson
Re: FS: SOLD Lighter Note LDR Volume Control / Preamp
« Reply #5 on: 22 Feb 2016, 07:17 am »
SOLD
MarkR7
« Reply #6 on: 27 Apr 2016, 06:51 pm »
If anyone else one is looking for one of these, I am selling one.  See my ad in the Trading Post... it will be up shortly.
