MQA?
0 Members and 1 Guest are viewing this topic. Read 4342 times.
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
MQA?
« on: 9 Feb 2016, 05:56 pm »
I don't know if this was discussed here before, but will the BDP be able to handle this new format? I heard a demonstration a while back, and was quite flabbergasted...
https://www.meridian-audio.com/news-events/world-first-meridian-firmware-update-enables-mqa-playback/
  • The Demo is Everything!
    • http://www.bryston.com
Re: MQA?
« Reply #1 on: 9 Feb 2016, 06:17 pm »
Hi Anonamemouse
Yes the BDP-2 is capable of decoding MQA (as well as our new BDA-3 DAC) as we use the XMOS chip which is what MQA requires.  There is a lot of discussion over on this side of the pond though pro and con so we are going to adopt a wait and see policy at this point.
james
zoom25
Re: MQA?
« Reply #2 on: 9 Feb 2016, 09:02 pm »
What about BDP-1?
Re: MQA?
« Reply #3 on: 9 Feb 2016, 10:11 pm »
What about BDP-1?
Hi
No sorry - the BDP-1 does not use the XMOS chip.
james
Jimmy71
Re: MQA?
« Reply #4 on: 10 Feb 2016, 05:48 am »
Hi
james
Hi James how about the BDA-2?
Re: MQA?
« Reply #5 on: 10 Feb 2016, 10:43 am »
No sorry the BDA-2 does not use the XMOS either.  Only the BDA-3.
But just to be clear we are not rushing into MQA - there is still much to be discussed regarding the value of yet another format.
james
Re: MQA?
« Reply #6 on: 10 Feb 2016, 02:31 pm »
I've always been suspicious of special demonstrations.  Meridian is a quality company, but my first thought of such demonstrations goes to Bose.
R. Daneel
Re: MQA?
« Reply #7 on: 11 Feb 2016, 09:48 am »
james
Hi James!
But I was under the impression that XMOS is exactly what the BDA-2 uses. What chip does BDA-2 use then?
Also, if you play MQA through BDP-2 with the BUC board and conect it via AES to BDA-2, would it work?
Cheers!
Antun
Re: MQA?
« Reply #8 on: 11 Feb 2016, 11:22 am »
Hi James!
Cheers!
Antun
[/quote
Hi Antun
I will check with engineering on the XMOS for you - you may be correct but not sure on the software requirement on the BDA2.
I have never tried that so not sure if the MQA on the BUC to the BDA2 would work.
james
R. Daneel
Re: MQA?
« Reply #9 on: 11 Feb 2016, 12:13 pm »
Hi James!
Cheers!
Antun
[/quote
Hi Antun
james
Hi James!
Okay, please check with engineering and let me know.
Cheers!
Antun
Re: MQA?
« Reply #10 on: 11 Feb 2016, 05:23 pm »
Hi James!
Cheers!
Antun
Hi
I checked with engineering and the BDA2 does use an XMOS chip but it is an older version and can not accommodate MQA.
james
R. Daneel
Re: MQA?
« Reply #11 on: 11 Feb 2016, 08:26 pm »
Hi
james
Hi James!
Thank you for the information!
Do you think BDP-2 with BUC could output it to BDA-2 via AES connection?
Cheers!
Antun
