Bryston 1B question
0 Members and 1 Guest are viewing this topic. Read 839 times.
bunkertoy
Bryston 1B question
« on: 7 Feb 2016, 07:47 pm »
I finally got myself a Bryston 1B
My question is about the use of the Switched and unswitched outlets.
It appears that I have 3 outlets 2 switched and 1 unswitched
Is it ok to plug my 3B bryston into this outlet ?
under the middle outlet it says max 500watts
Any help or opinions you can provide would be great.
I'm also worried that the preamp doesn't have a mute button like the BP4 which i was using prior to this.
The BP4 didn't have a phono stage, which is why i'm swapping it out.
Thanks all
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston 1B question
« Reply #1 on: 7 Feb 2016, 11:47 pm »
Thanks all
Hi
NO do not plug the amplifier into the 1B it will draw too much power.  Please plug the amp directly into the wall.
james
bunkertoy
« Reply #2 on: 8 Feb 2016, 12:15 am »
Thanks James for your quick reply
