0 Members and 1 Guest are viewing this topic. Read 40797 times.
I guess when one pays that kind of money in one's pursuit of sonic perfection, one has elevated oneself socially to the point that one can start throwing "ones" around, and does. "One can lead a horse to water but one can not make it drink", eh?Give me a break.Here's something to consider: I never said I couldn't hear a difference between cables, did I? One seems to have missed that.My microphone cables cost me $10 USD a foot in 1990 dollars, as did all my analog interconnects in my studio. By pro standards of the time I was nuts and looked at sideways, but I did it because I could hear the difference.What I am arguing about is the wisdom of spilling $7500 big ones on speaker cable instead of buying, say, better speakers—or positioning your speakers better in your listening room. I see you have yours firing straight ahead; almost never optimum under any circumstances.
I can appreciate Russel's point, these are most likely the most insanely expensive cables on the market. However they are not intended to be used with the vast majority of systems. As much as I hate formulas, a system budget of about 20% allocated to cables means there is a place for these; so if your system is worth at least 50K and you're wondering if there's a bottle neck, these might be the answer. But for anyone with a system where the speakers and components do not cost as much as these cables, these cables would not be appropriate. As Russell pointed out, you'd be far better off spending a few thousand dollars more on new speakers (or an amp etc) than new cables.
I disagree about the budget percentages for cables. Way too simplistic. Listen and evaluate the impact, then decide on what level to purchase based on the sound.
Windchaser - These are not most expensive cables on market - witness Crystal Cable PC $16,500, Siltech Emperior Speaker Cable $40,000, Nordost $33,000, Audioquest Speaker $76,000, MIT ACC $80,000 and the list goes on through another half dozen brands at least.
I was surprised along the way to find for me that cables contributed much more than I expected to the mix.
