New Sonicap Platinum, the best caps made.
0 Members and 1 Guest are viewing this topic. Read 4357 times.
Danny Richie
    • http://www.gr-research.com
« on: 26 Oct 2004, 01:58 am »
Any way you want to measure them they outperform any other cap (This was as per the manufacturer).
I have personally auditioned many caps and have yet to hear one that outperforms the new Sonicap Platinum.
These are a unique Teflon composite design that puts them above all others in all sonic aspects, to my ears.
I am excited about these caps and I am excited to now have these in stock and available.
All are rated at 800VDC.
Best of all they are not overpriced. For a cap of this type, they are very reasonably priced.
Sizes and prices are as follows:
.01uF - $16.40 each
.022uF - $17.20 each
.033uF - $18.00 each
.047uF - $18.40 each
.1uF - $19.20 each
.22uF - $28.20 each
.33uF - $31.80 each
.47uF - $44.00 each
1.0uF - $76.40 each
Not stocked but also available are 2.0uF, 3.0uF and 4.0uF.
guest1632
  • Guest
Re: New Sonicap Platinum, the best caps made.
« Reply #1 on: 26 Oct 2004, 08:06 am »
Quote from: Danny
Any way you want to measure them they outperform any other cap.
Sizes  ...
Danny Richie
Caps
« Reply #2 on: 27 Oct 2004, 04:42 pm »
Hi Danny, Have you tried these new V caps, that Chris makes? If so, what were your impressions? Ray -
I know two that have, including one member here on AC and I have heard their impressions, but I have not tried them myself, so just to stay on top of things I ordered a sample V-cap today.
jeffreybehr
« Reply #3 on: 1 Dec 2004, 08:47 pm »
I wonder why so many manufacturers of audio-quality capacitors are skipping the highly-common-value-in-the-E6-series '15', as in 0.15uF and 1.5uF.  The former is quite common in vacuumtubed poweramps, and not having a 0.15 forces us to use a 0.22 (or combine a 0.1 and a 0.047 for even-more money!), thereby altering the frequency poles the designer chose.
Any reason, Danny?
BTW, your prices are quite low for teflon-film caps and not so much more than those for, eg, TRT DynamiCaps.
(For those of you not familiar with 'E6', 'E12', etc., it's an industry-standard method of getting from 1n to 10n in 6 or 12 (or 24, etc.) steps.  The E6 values are 1, 1.5, 2.2, 3.3, 4.7, and 6.8.  The 12-series adds 1.2, 1.8, 2.6, 3.8, 5.6, and 8.3.)
Danny Richie
« Reply #4 on: 10 Dec 2004, 01:21 pm »
Any reason, Danny?
I don't pick the values the manufacturer makes. I just sell them. But I do know that if you have a need for these values they will be glad to make them for you. Quantities needed for custom values to be made are smaller than you think.
Yea, I don't think the manufacturer is trying to recoup all his development cost in the first run of caps. Prices are based on cost to produce and not a how much can I get for these mentality. If I felt like they were over priced then I wouldn't sell them.
