0 Members and 4 Guests are viewing this topic. Read 196574 times.
Thanks for commenting on your experiences. Was 256 with the U12 a significant step up from 128 over DOP? I'm curious enough because I have a U12 that is currently not in use. I'm wondering if inserting another piece in the chain will cause some loss of detail versus going straight into the USB on the X20. There is also the question of what type of HDMI cable to use (I have no idea if the quality of HDMI cables will impact the sound)
Hi Guys...is the x20 known to sound...1)Neutral2)Warm and analogue/organic3)Cool and detailedThanks
Listening to classical orchestral with dsd256 and the u12 I found improved transients and bigger soundstage. The improvement was slightly better and more satisfying than moving from dsd64 to dsd128. I used the shortest HDMI cable I could find for the i2s connectivity (30cm). Adding devices in the digital realm has less impact than analog but make sure you have short cables! with good connectors!
1&3
Thanks Everyone for your feedback.@Modified...yup I am seeking #2 for sure. Full, warm, romantic and analogue sounding. Btw...do you have experience with the Teac UD503 and would they qualify too? Sorry...I know this is a Gustard thread...but I do need recommendations for under 1K dacs...new or used which fit the criteria. Prominent and unrefined HF is a definite no no. Anyone else? Thanks for your help!
Yes, "probably" is a good guess as the AKM DAC chips are reputed to be warmer than ESS chips. However, everything you do can change the sound. I can make an ESS DAC sound warm as anything. We have no idea how this new AKM Gustard sounds versus the new ESS Pro Gustard unit until someone A/Bs them. The new ESS DAC chips may indeed sound more "warm". We have no idea yet until one arrives here...hopefully shortly. Other companies are shipping or about to ship DACs with the new ESS DACs in them so there will be feedback over the next several months.....starting possibly with the comments on the Resonessence unit about to be reviewed on 6moons. Stay tuned.
No real info there, except he says it sounds dry and clear......compared to what? And he is listening on headphones. We need a direct A/B with the new Pro unit using speakers to know anything about the sound differences. I could make is sound way less "dry". No problem.
