Quick question for X20 users:Do you use balanced connectors or RCA connectors into you preamp? I ask because I've just ordered a new Don Sachs SP14 preamp, and I'm wondering if I should have XLR connectivity added. (I know. It is a personal decision for everyone.)
Hi, guys, great thread... Since I`m not much of an expert in the field of DACs I`d have a newbie question - If I get myself Gustard, can I connect it to Raspberry, which would take a role of a renderer in this case (connected to my NAS) with let`s say Rune or Moode installed? How would I connect the two - by USB cable? How about purchasing a device like Auralic Aries - would that be a better option? I guess it should be connected via USB cable to the Gustard or maybe spdif/toslink? Someone mentioned High Speed USB Isolator - is that a mandatory part in this constellation or does it just contribute to better SQ? Any help would be much appreciated..
Chris,Very cool info. It's much appreciated.Keep on truckin'...Just another 10 days till I'm back in my house with my upgraded system in an empty living room. Michael
As I thought, the issue was user error. I got it working. It will be interesting to see how this compares to PCM
I couldn't get my Gustard to convert PCM to DSD. How did you do it?
The issue was in my settings in Audirvana. I adjusted it to select DSD over PCm 1.1 and it then let me convert to DSD. Once that was fixed, the Gustard automatically switched from PCM to DSD
Thanks. hmmm... says it has trouble with the Volume control if i do this. (I really don't want the pre-amp back in the system)
Ok its been almost 1 month that I have had the clock soldered into the gustard on the output board and 2 weeks that I have used an external 5V PSU running to a twisted pear trident 3.3V regulator right in front of the clock. As I mentioned before the clock mod is a major upgrade, perhaps only beaten out by the success of DSD512. This is a relatively easy step to do provided you have soldering skills and the knowledge to do it. Using the gustards internal PSU is the easiest way to do this, but using an external PSU with a regulator by the clock is another step up from the gustard's internal PSU.The easiest (low power) clock to source is a crystek CCHD-950x from mouser http://www.mouser.com/ProductDetail/Crystek-Corporation/CCHD-950X-25-100000/?qs=L4klnTtkofObrfUJUtC8ig%3D%3D it has a very low current draw and is favorably reviewed in other threads. You only need 3 wires soldered to this clock to make it work, pins/pads 2, 3 and 4. You also need to make sure you have a .1uf ceramic capacitor type x7r between the Vin and ground pads. There are 4 pads around the output boards coax tower one is even labeled 3v3 (3.3 Vdc). Using a ohm meter with continuity test you can easily identify the other two using the coax tower as reference (center signal, outer part ground). Now if you attempt this and make a mistake it is not my fault, you need the basic knowledge and soldering skills to do this, if not find someone who can. The best part this mod is easily reversible, just desolder the wires from the pads and re-connect the coax cable.So to make a significant upgrade to your dac I suggest doing the first 3 AC mods in Ric Schultz level 1 mod (twist AC lines, replace fuse with audiophile fuse or wrap in copper foil, remove steel hardware from trannys and raise on cardboard) and replace the coax cable with a clock soldered on the output board as described.Those 4 steps will significantly raise the level of your dac. BTW clocks take time to break in and probably account for the majority of a new dac's break in. I felt after 100 hours with signal that the clock was pretty settled and any change from there was very subtle.
