Roderstein resistor colour codes
0 Members and 1 Guest are viewing this topic. Read 1473 times.
jules
« on: 25 Oct 2004, 10:47 pm »
Hi all,
I've just received a batch [92] resistors for use in an Elma stepped attenuator. I'm perplexed though. These are Roderstein (Resista) resistors from Michael Percy and they use  5 band [on green] and 6 band [on blue] colur coding system. I'm familiar with 3  or 4 band systems but can someone tell me where I can find a decoder for 5 and  6 band systems?
jules
peranders
« Reply #1 on: 27 Oct 2004, 08:28 am »
It's pretty easy.
RED BROWN (in one end) which all of your resistors have is 200 ppm temp coeff, 1% tolerance.
If you go from the other end
number, mumber, number, multiplier, tolerance, temp co
http://www.electrician.com/resist_calc/resist_calc.htm
http://www.bit-tech.net/article/68/
http://users.telenet.be/educypedia/electronics/electroniccalculatorsresistor.htm
JohnR
« Reply #2 on: 27 Oct 2004, 01:09 pm »
I don't think I know about six bands :o Thanks for that info peranders ;)
Anyway, being more cautious now than in my reckless youth, I recommend always double-checking with a meter anyway, before inserting into board/switch/whatever.
