0 Members and 1 Guest are viewing this topic. Read 11739 times.
Is there a subwoofer output (a real weakness of the KEF X300A)?
Type of analog inputs (RCA, TRS, XLR)?
Although I remember Jim saying the amplification was 50W/50W per speaker, that seems to be missing from either the Overview or Specifications.Steve
The Salk Powerplay site states "One hundred clean class D watts per speaker with low signal to noise ratio of 104db."
Yes, but not on the main Salk Sound website PowerPlay pagehttp://salksound.com/powerplaymonitor-home.htm
Here is some preliminary information on these monitors:Fully active 2-way speaker system.One master - one slave speakerHiquphon 3/4" slik dome tweeterSeas 6" wooferFront slot port for versatile placement100 watts per speakerUSB input up to 24/192 - no external DAC requiredS/PDIF coax input up to 24/192 - no external DAC requiredOne pair Analog inputs - RCATouch sensor on master speakerRemote control (volume and input selection)Size: 8" W x 13" D x 16" HAvailable in any standard or optional custom finish- Jim
What is the amplifier wattage for woofer vs tweeter?
50 watts each.- Jim
Cool beans!Any images of the remote or the back of the speakers?
Any bass/treble adjustments?
Any details available on the cabinet (TL or simple port); DAC (chip, source power needed); crossover (crossover frequency/slope); or amp (size per driver, type) design?
Will there be a simpler/cheaper analog version?
Yes active speakers are typically a very good value. You save on power cords, interconnects, cabinets, and power supplies. Plus the amps have been matched to the drivers and without the crossover in the way can be smaller to deliver the same spl.
Who designed the DSP crossover?
How is excess bass reinforcement from close to wall/corner setups accounted for?
Again, crossover details (frequency/slope)?
Why a C7 power input?
What are the SPDIF and amp outputs for?
What is the USB mini female jack for?
Why no XLR inputs? (Guess the design isn't balanced, so it won't be going to the studio.)
Again, any image of the remote?
Any idea how they compare to established active monitors like Adam A7X, Dynaudio Excite X14A, Focal Solo 6 BE, Genelec M040, or Neumann KH120?
