question about a preamp for xtreme monos
0 Members and 1 Guest are viewing this topic. Read 3623 times.
vpolineni
« on: 25 Oct 2004, 01:40 pm »
I'm looking for a preamp to go with my xtreme monos... it's down to a tempest (obviously a great match) or a tubed preamp.  If I get the tempest, there will not be any tubes in my system and I don't like the idea of that.  The tubed preamp has an input impedance of 100Kohm and an output impedance of 130 Ohm.  I read in an earlier post that the input impedance of the xtreme monos is measured at 18kohm.. is this a good match?
audioslave
tube preamp
« Reply #1 on: 25 Oct 2004, 01:47 pm »
I talked to Klaus at HE2004 about tubed preamps and he recommended Rogue Audio as a good match for the Stratos.  :idea: I would not do the model 66 but rather the 99 model. This preamp (particularly the "magnum" version) is a more suitable match considering the fact that you have the extreme monos. If you need to double-check, you can always call Klaus.
Christophe35
« Reply #2 on: 25 Oct 2004, 04:44 pm »
Did Klaus told you how these preamps (rogue 66 and 99) compare with the tempest ?
Christophe
byteme
« Reply #3 on: 25 Oct 2004, 06:15 pm »
I can chime in here, the deHavilland Ultra verve is  UNREAL!!!  I'll PM you when I get a chance.
vpolineni
« Reply #4 on: 25 Oct 2004, 06:24 pm »
thanks brian.
doug s.
  • makin' music
Re: question about a preamp for xtreme monos
« Reply #5 on: 25 Oct 2004, 06:49 pm »
Quote from: vpolineni
general rule of thumb is that a preamp's output impedence should be no more than 1/10th that of the amp's input impedence.  so, max output impedence of a preamp w/the xtreme would be 1.8kohms.
based on this, i would *not* use the rogue magnum 99.  even tho it's rated at 150 ohms output impedence, i owned this pre, & its real-world output impedence is likely somewhere in the 2k-2.5kohm range.  it would not adequately drive a 5m interconnect run into my 25kohm input-impedence marchand x-over.  bass was mia, & treble was reduced.  crossing the outputs w/resistors & easily hearing reduced sound level, was what gave me the actual 2k-2.5k output impedence of the rogue.  (i forget which walue risistor i needed, to effect this test).   the cary slp-98, which i tried after the rogue, had *no* problems whatsoever driving this load, & it was rated at 650 ohms output impedence.
there were other reasons i dint like the rogue - it was *way* coloured in sound, it was way too bloomy, it was wery microphonic.  the cary slp-98, which some consider to be coloured, was wery neutral, in comparison, & a far better match to my system.
my melos music director was so much better than the cary, i stopped looking for preamps...   :wink:  it's presently being traded for another single-ended music director (mine's balanced, & i don't need that feature), that has a $700 tubed wolume control mod & three more line inputs.   i can't wait!  the tubed wolume pot is supposed to be even more transparent than their famed (but unreliable) photentiometer.   :mrgreen:
doug s.
vpolineni
« Reply #6 on: 25 Oct 2004, 07:14 pm »
doug,
  would the preamp i'm thinking of (with an output impedance of 130 ohm) work?
doug s.
  • makin' music
« Reply #7 on: 25 Oct 2004, 07:39 pm »
doug,
input impedence of your amp is rated at 18khz.  any preamp's output impedence should be *max* 1/10th that amount, or in your case *max* 1.8khz.  your preamp's rating of 130 ohms output impedence is *way* lower than your amp's output impedence rating, so you should be fine.
but, i related my story w/the rogue magnum 99 which i owned, as a caveat...   its *rated* output impedence of 150 wasn't low enuff to drive my marchand's input impedence of 25kohms, yet the cary slp-98's 650 ohms output impedence was more than low enuff.... :wink:
doug s.
avalon65
« Reply #8 on: 25 Oct 2004, 08:01 pm »
Doug,
Which Odyssey amp did you have connected to the Rogue? I'm surprised that Klaus would supposively recommend their amp if it didn't mate well.
doug s.
  • makin' music
« Reply #9 on: 25 Oct 2004, 08:07 pm »
Quote from: avalon65
Doug,
i wasn't using an odyssey amp.  amp's impedence is not relevant in this case, as it was the marchand active x-over seeing the load, & the marchand's input impedence is 25kohms.  the amps at the time were electrocompaniets, w/input impedence of 100kohms.
perhaps, w/really short ic's between amp & pre, ya could get away w/the rogue w/the odyssey amp.  but, in my limited experience, i heard two tube amps which were far nicer than the rogue magnum 99.  i even liked my s/s linn kairn preamp better than the rogue.
doug s.
Randy
« Reply #10 on: 26 Oct 2004, 02:22 am »
I use a BV-Audio preamp P-1 with my pair of Mono Extremes.  Great match, not to say that the Tempest would not be just as good.  However, the BV is fabulous- clear, clean, and dynamic.  Check out their website.  They have a new model also, the P-10.
I bought my Odyssey amps about two years ago.  Best $2500 I ever spent.  I can say the same for the BV, though it was about $1350.
