Help! Anyone familiar with Audirvana ?
0 Members and 1 Guest are viewing this topic. Read 2103 times.
rustydoglim
« on: 27 Jan 2016, 07:29 pm »
I have a new customer running into problem using Audirvana to play DSD file with IDA-8.
Can anyone share your setup on Audirvana?
JohnR
Re: Help! Anyone familiar with Audirvana ?
« Reply #1 on: 28 Jan 2016, 07:08 am »
I don't have the current version (or know anything about the IDA-8), but it may be necessary to set the "Native DSD capability" option in the Audirvana Preferences to "DSD Over PCM".
firedog
« Reply #2 on: 28 Jan 2016, 12:35 pm »
If you don't get an answer try over at computeraudiophile.com. Lots of users there.
avta
gregfisk
« Reply #4 on: 28 Jan 2016, 08:20 pm »
Like John said, I'm pretty sure you need to go into the Audirvana settings but I don't know anything about the Ida-8 either. I can look at the end of the day if your client hasn't figured it out by then.
Greg
