DAC to use with my iMAC?
0 Members and 1 Guest are viewing this topic. Read 2284 times.
albireo13
« on: 26 Jan 2016, 11:48 am »
In our bedroom I have a stereo amp hanging off our iMAC driving a pair of  Energy RC-10 speakers. It is used for casual music and background, when we work on the computer.  The amp is fed analog from the headphones output on the MAC.
  I want to improve the audio quality and find a decent, basic DAC to use.  One problem I want to solve is to get rid of hum, and digital noise I seem to have with the analog connections.
Anyway, is there a good DAC for $100 or less?   This is not an audiophile system so, I don't need high-end.
Should I look for USB DAC or TOSLink DAC?
Thx,
Rob
mcgsxr
Re: DAC to use with my iMAC?
« Reply #1 on: 26 Jan 2016, 11:58 am »
I enjoyed my time with both the Audioquest Dragonfly and HRT Music Streamer USB DAC's.
Both would improve sound quality I don't doubt.
As for the noise, is it constant or variable?
srb
« Reply #2 on: 26 Jan 2016, 04:15 pm »
The Schiit Modi 2 is a USA-made USB DAC with 2-year warranty for $99.  It should work fine for your application, and a USB-powered DAC doesn't need an external wall wart power supply.
There is a 15-day return, but it does require a 15% restocking fee +  return shipping, however chances are you will be happy with it.
Doublej
« Reply #3 on: 26 Jan 2016, 06:30 pm »
I'd wait for the new Audioquest Dragonfly that is due out at $99.
Vincent Kars
  • The Well Tempered Computer
« Reply #4 on: 26 Jan 2016, 08:30 pm »
The hum might be an earth loop.
Try PC and amp plugged in the same block.
Toslink is a fully galvanic isolated connection between PC and DAC (plastic fiber).
Might solve this problem as well (if the amp without any connection to the PC stops humming)
albireo13
« Reply #5 on: 29 Jan 2016, 05:29 pm »
Yes, the noise seems to be a ground loop, or earth loop.  It is actually not a hum but, noise from digital activity.  You can hear a low level "chatter" going on that changes with processor activity.
A TOSlink solution would probably be best.
erniek
« Reply #6 on: 29 Jan 2016, 07:36 pm »
I've used the MF VDAC2 with my IMAC and thought it sounded quite good.
