Any Kiwi or OZ use circuit breaker with their AKSA?
0 Members and 1 Guest are viewing this topic. Read 1486 times.
SamL
« on: 27 Feb 2003, 09:15 am »
Where did you get your circuit breaker?
Is the one carry by jaycar good enough? Stock number SF2293.
Since AKSA is actually mono block, I plan to use two power switch but through one IEC. Should I be using 2 circuit breaker? What Amp should that be?
TIA,
Sam
