Recomendation of an Amp for LGK 1.0
0 Members and 1 Guest are viewing this topic. Read 1493 times.
Fallingsnowfy
« on: 24 Jan 2016, 12:32 pm »
Good Morning
I need help im looking for an amp for LGK 1.0 speakers, Currently i own a Lepai 2020A but is ,making hizzing noise very annoying. I would prefer Pre owned or refurbished, my budget is 200 USD max.
If anyone knows or have heard a decent Amp i would be grateful for a suggestion.
Re: Recomendation of an Amp for LGK 1.0
« Reply #1 on: 26 Jan 2016, 03:55 pm »
Best source for used gear is Audiogon.com.
« Reply #2 on: 27 Jan 2016, 12:57 pm »
Here's a good amp for you:  Trends TA-10.2 ($189 USD); but the TA-10.2 SE ($225 USD) provides a better volume control (don't under estimate the value of a good volume control) and a bit more power supply capacity (don't under estimate the value of a beefy power supply).
manufacturer's link:
http://www.trendsaudio.com/index.php?option=com_fabrik&view=table&tableid=3&calculations=0&resetfilters=0&Itemid=29&lang=en
link to a good review:
http://www.digitalaudioreview.net/2011/05/trends-ta-102-se-class-t-integrated-amplifier/
