Khartago or Stratos?
0 Members and 1 Guest are viewing this topic. Read 2297 times.
radhk
« on: 24 Oct 2004, 11:51 pm »
Hi all, I'm new to this forum. Say Hello to all of you. I'm now considering to buy the power amp from Odyssey.
I'm using the speaker ProAc Tablette 2000s. Do you think the Khartago is enough to push my bookshelf speaker? The sound of my speaker is a little bit "fast" and "thin". Do you think the sound of Odyssey power amp match with it?
Any users of Khartago and Stratos can share their experience of using this two power amps? Besides power, what is the difference?
Another question is "Can I use two Odyssey stereo power amps for bi-amp connection?" Will the bi-amp configuation using two Khartagos be better than two Khartago Monos?
Thanks a lot for answering my questions.
Calvin
odysseyhk
« Reply #1 on: 25 Oct 2004, 12:29 pm »
I suggest you come to our showroom to hear the difference between the 2 models(I guess you are in HK).   You can loan a Khartago and try it at home.  If you think it is good enough, take the Khartago.  If your set-up need more power to explore its full potential, then go for Stratos.
We will help you as much as we can to make the right choice.
