I'm looking for a speaker box for X-LS Encore Kit
0 Members and 1 Guest are viewing this topic. Read 2248 times.
Blaser
« on: 21 Jan 2016, 03:32 am »
or preferably a flat pack any help would be greay
Re: I'm looking for a speaker box for X-LS Encore Kit
« Reply #1 on: 21 Jan 2016, 03:53 am »
These aren't  perfect but they do work and many people have had  great results using them
http://www.parts-express.com/dayton-audio-tw-050bk-050-cu-ft-2-way-speaker-cabinet-gloss-black--302-720
You can also get them in Cherry or Maple I believe.
You   will want to cut a  large portion  of the brace out  so it is  open from front to back. If you can, add a cross brace instead and line the cabinets with no rez.
In fact, here's a pair Ron built in  PE cabinets
-jay
NeilT
« Reply #2 on: 24 Jan 2016, 01:14 am »
They worked out great for me.
Blaser
« Reply #3 on: 24 Jan 2016, 07:28 am »
wow they are nice
 my problem is counter sinking the holes
lacro
« Reply #4 on: 24 Jan 2016, 03:54 pm »
If you get the PE cabinets, You may find someone here willing to cut the front baffle holes for you. The port could be cut with a hole saw by you, and just use Electra tube connectors or binding posts for the connections.
