0 Members and 1 Guest are viewing this topic. Read 2745 times.
If you position them in the D plane and sit at position C (or even B), you basically eliminate the first side reflection point. Still would be desirable to use absorption on the wall room in front of you, but the wall behind you would be far away enough that you could consider the use of some diffusion.
Is the drop ceiling T-bar acoustic tile ?
Now you can sell the tractor, buy a push mower, and spend all the extra $ on more music & dinners for Mrs. Rocka.
Working with architectural plans for 40+ years and you've sort of confused me (congrats).
I assume the heavy lines represent the basement walls and that you'll need access to both left and right ends.
For 2-channel I'm thinking speakers at D, listening position at B ...
I believe so. This is what it looks like (picture is not of the notch area, but of the area to the right of my diagram - I am only providing a picture to show the ceiling tiles.):Yep, that's what I was talking about. Depending on the amount of space, how the ducts (?) & electrical are run, you should be able to push up on each tile & see the extent of the space above. (qualifier- try to keep the tile level as there is always dust, bits of tile, and occasional other odds & ends left on top out of sight - lift towards corners rather than middle) Grab your flashlight & take a look. As a finished space the prior occupant or even builder may have installed insulation in the floor joist channels to knock down noise transmission. You'll be able to see if ducts are insulated, and how much space you may have to work with for adding additional insulation on top of the ceiling tiles. And seating will be for one person only - me - king of the basement! Exclusively 2-channel.Well, you might want to have an extra chair or two for visitors. Never know when I might make it back east. Ha! Actually, I was hoping for NO grass at all, but this home does have a small patch in front only. Hmm ... Wonder if I can cover that with pine straw and a few plantings? Hmm ... The option of having NO grass is SO appealing!Some friends up in Bellingham are doing that exact thing, though given our climate they are turning their small front yard into a "rain garden". Lots of options for no maintenance landscaping these days. Should be achievable without too much time & $ . I like the idea, am getting tired of fighting the moss in my yard.
