Bel Canto Ref 500M Amps ***SOLD***
0 Members and 1 Guest are viewing this topic. Read 3587 times.
brooklyn
« on: 20 Jan 2016, 07:04 pm »
Hi everyone, my music listening has changed over the last few years and I’ve haven’t set up and used
my audio system for a while so up for sale is a pair of Bel Canto Ref 500M amps in excellent condition.
These two amps powered my Magnepan MMG’s and never broke a sweat.. The amps are double boxed
but one of the outer boxes is not the original.
Both amps will be shipped in two separate boxes with Fedex ground within the ConUS only. Paypal and
shipping fees will be included in the price. $2300.00... New Price $1800.00 ***SOLD***
Bel Canto Ref 500M
Maximum Power Output: 500W 4 ohms, 250W 8 ohms
Power Output 1% THD: 450W 4 ohms, 225W 8 ohms
Minimum Load: 3 ohms
Peak Output Current: 35 amperes
Frequency Response: +/-3 dB 1.5Hz-70KHz, all loads
THD+N: 0.003% 1W, 1KHz, 4 ohms
IMD (CCIF): 0.0003%, 1W, 14:15KHz, 4 ohms
Output noise: 35uVRMS A-weighted 10Hz-20KHz
Voltage gain: 27dB (single ended or balanced input)
Damping factor: >1000
Output Impedance at 100Hz: <8 milliohms
Dynamic Range: 121dB
Input Voltage for Max Output: 2Vrms
Input connections: Single-ended RCA or balanced XLR
RCA input impedance: 100Kohms
Balanced input impedance: 200Kohms
Output connections: 1-set WBT Nextgen 5-way binding posts
Power On usage: 10W
Power Off usage: 0.0W
Internally Set Operating Voltages: 100-120VAC or 230-240VAC 50/60 Hz
Size: 8.5 x 3.5 x 12[inches], 216 x 88 x 305[mm] (WxHxD)
Weight: 15 lbs, 7 Kg
« Last Edit: 20 Apr 2016, 04:07 am by brooklyn »
brooklyn
Re: Bel Canto Ref 500M Amps
« Reply #1 on: 27 Jan 2016, 03:55 pm »
Bump.. $2200.00
« Last Edit: 5 Feb 2016, 05:26 pm by brooklyn »
brooklyn
« Reply #2 on: 5 Feb 2016, 05:25 pm »
Bump for $2100.00
brooklyn
« Reply #3 on: 12 Feb 2016, 03:08 pm »
Bump for New Price $2000.00
brooklyn
« Reply #4 on: 19 Feb 2016, 12:34 pm »
Bump...
brooklyn
« Reply #5 on: 26 Feb 2016, 05:18 pm »
Bump..
brooklyn
« Reply #6 on: 4 Mar 2016, 06:14 pm »
Bump for New Price $1800.00
brooklyn
« Reply #7 on: 12 Mar 2016, 04:35 pm »
Bump..
brooklyn
« Reply #8 on: 19 Mar 2016, 04:55 pm »
Bump..
brooklyn
« Reply #9 on: 26 Mar 2016, 03:52 pm »
Bump..
brooklyn
« Reply #10 on: 3 Apr 2016, 04:27 am »
Bump.. ***SOLD***
« Last Edit: 20 Apr 2016, 04:08 am by brooklyn »
