0 Members and 1 Guest are viewing this topic. Read 4967 times.
Yes, there IS confusing info out there regarding best practices. However, IMHO, you should connect the shield on both ends.Dave.
Good Boy...
The best RCA analog interconnect cables are made with a coax that has a heavy braided shield. With the foil being optional.
Not in my universe!AFAIAC, the best-sounding RCA analogue interconnects are made with solid-core 'twin-ax' ... which is:* 2x solid-core conductors (which carry the signal and signal ground), with* a braided shield (which, if grounded) shields the signal wires inside.I use Belden Profibus - I think its code is 3789A.The optimum way to ground the shield is to have a 'pigtail' of shield wire (individual strands picked apart from the braid and then twisted into one wire) which connects to the earth terminal on either the source component case or the destination case. This way, RFI picked up by the shield has no connection to signal ground.Regards,Andy
I agree for the most part, but the signal and chassis grounds are directly connected in most components. Even better would be to ground the cables' shields to the same point the components are plugged into as many components do have some isolation between safety ground and chassis/signal grounds. This could provide a very low impedance path for noise and not interfere with the signal/chassis ground. A few cable companies are currently doing this, but of course now you need ground cables for your signal cables, etc...
Signal ground does not touch mains/chassis ground anywhere in my system, anyway.Andy
Ok, but these days most of the time signal and chassis are directly connected and the whole thing floats together. Shields are connected to the chassis close to the chassis jack. Sometimes, chassis/signal is isolated from safety ground by one of several methods. In this case, the shield is basically part of the chassis and in balanced equipment should be connected at both ends. For single ended only one end.
safety ground,man oh man,what about double-insulated/battery equipment,your cables wont work...
I like to refer to this as a "drain" rather than mix it into the description of a "ground".EV3
And the idea is to drain to the low impedance end since that's the less likely end to have the drained signal impressed onto the desired audio.
I like to refer to this as a "drain" rather than mix it into the description of a "ground".And the idea is to drain to the low impedance end since that's the less likely end to have the drained signal impressed onto the desired audio.EV3
Yes, good terminology, EV3 - particularly as the shield is 'draining' any collected RFI to earth. Andy
