Need help choosing a modell
0 Members and 1 Guest are viewing this topic. Read 1930 times.
Johnb
« on: 24 Oct 2004, 08:13 pm »
I have listend to the Omega Super BPS and they sound great, however they need to pleaced a bit away from the rear wall wich I cant in my room.
Since there are so many modells to choose from I need som help.
Since i have a big room probably 20 long and 13 wide i looking at some of the bigger speaker Grande 6, TS 33 and the Minuets.
My system consists of Opera Audio Reference 2.2 Audion Sterling monoblocks (pp 38w class a with KT88).
I want som bass output aswell althougt i am planing on using them with subs.
I listen mostly to rock and sometimes loud and among the record there are some badly produced ones so a shouty trebble is not for me.
Anny suggestions or differences among thew modells woud be very helpfull.
John
Louis O
« Reply #1 on: 27 Oct 2004, 01:23 pm »
Hi Johnb,
Thanks for your post. I'm really happy you liked the BPCs. They do need a lot of space in the room. From reading you post, I think the Grande 6s would be the way to go. They have a very well balanced sound, easy to place and not shouty at all. Thay also blend easily with subwoofers too.
Thanks again,
Louis
Johnb
« Reply #2 on: 27 Oct 2004, 08:57 pm »
Thank you for the reply, I will try to listen to the Grande 6 when I visit my dealer next time, by the way are the rumours about a floorstanding modell true? :D
