SOLD : Jolida JD302CRC / Upgraded Caps / Lots of tubes
0 Members and 1 Guest are viewing this topic. Read 1953 times.
hey folks
Up for sale is my Jolida JD302CRC (Maryland).  this is a great sounding EL34 based integrated amp. Coupling and signal-> ground caps have been upgraded to Clarity MR series The CRC version  is equiped with  a HT bypass input, 3 sets of RCA inputs,  a set of balanced/XLR inputs, a variable and fixed  pre-out, and a front panel .125" mini jack for connecting your  portable devices,. Both  8 and 4 ohm speaker taps are on the rear panel The amp has individual bias pots for each of the 4 output tubes that can be set via the easy bias LED's or by using a meter in conjunction with the  top  mounted  test points.
Tubes inluded are as follows:
Canada Fuller EL34g with approx 1 yr  use
JJ Kt77  approx 3 months  use
Shuguang EL34B  6 months  use
Early 60's Amperex ECC83 (large Halo getter) from TC tubes , 2 prs  1 18 months use, 1 NOS
Mullard CV4024 / 12AT7  2 prs,  1 from Jim McShane  20 months use, 1  NOS from  Mullardtubes.com
All the tubes above sound great, , none have any issues that I'm aware of
I can also include a pr of EH 5751 gold pins  (less than 6 months use) and a pr of Sylvania  12AT7's (used).
I don't really have a dedicated power cord for this amp but I can probably come up with something... I do have a long Asylum Power cable  (Belden 19364, P&S 5266-X wall & Schunter 4300-0603 IEC terminals)   made by Take 5 Audio I can include but you['d have to shorten it up (it's 17' long right now, you could make a few cords out of it!).
I've got the original box (double box), packing, remote  (minus 1 rubber foot), manual, and warranty card which was never  filled out.
I've had the amp for a couple years although it has been sitting  since August. I've never had any issues with it,  it's a rock solid amp and sounds great.  It's time for someone else to get as much enjoyment out of it as I have .
This is 2nd hand information (I wasn't told this direct from Jolida) but apparently this amp will also run the KT88's but  you will need to bias  with a meter instead of using the  EZ bias  feature
-jay
« Last Edit: 27 Jan 2016, 03:29 am by Captainhemo »
Re: SOLD : Jolida JD302CRC / Upgraded Caps / Lots of tubes
« Reply #1 on: 27 Jan 2016, 03:28 am »
SOLD
