FS: Marsh p2000t tubed hybrid preamp with extra set of Tung Sols
0 Members and 1 Guest are viewing this topic. Read 908 times.
KKM
For sale is the Marsh p2000t tube hybrid preamp for $779. Will also consider reasonable offers. Buyer pays for shipping.
The preamp uses a pair 5687 tubes. The sale includes an extra pair of Tung Sol 5687, the installed tubes are Raytheon, having 2 different sets provide flexibility to customize the sound to your liking and play into synergistic arrangements with your other components.
This preamp is a superior performance tube preamp with triode tube, one of the most linear devices ever developed and designed for the lowest distortion possible. Here it is combined with the FET, creating a new and entirely modern circuit called the “Trans-Mu amplification stage." This brings out all the benefits of the triode tube- extremely low noise, wide frequency response, and low distortion - and eliminates the triode's drawbacks. Each channel uses two triode tubes with a push-pull output for low output impedance. The P2000t is able to drive even the longest cables without music deterioration. The filament voltage is direct voltage through a powerful C-multiplier filter, which ensure the lowest noise and the longest, most reliable operation. How low is low? Dead quiet-so you can hear even the most subtle elements in the music. Marsh-designed capacitors provide great accuracy and high-resolution of details- for the most realistic music reproduction possible and for reliable, long-life performance. Both line amplifiers are fitted with remote 12VDC control for custom installation and easy on/off control of other equipment in the system.
MSD-P2000T Specifications:
Frequency Response, 20-20,000 Hz +/- 0.1 dB
THD+noise at 1 Vrms, 20-20,000 Hz <0.05%
Input Impedance 50 kOhms
Maximum Gain 23 dB
Signal to Noise ratio, A weighted 90 dB
Maximum Output at 1kHz 8 Vrms
Crosstalk at 1 kHz -90 dB
Crosstalk at 10 kHz -90 dB
Input Power AC 110-120 V, 60 Hz
Power consumption 30 W
Size 19" W x 4 1/2" H x 13" D
I found it great pairing with SS amps as well as class D amps, had to give it up since the family wants to go with a HT set-up.
The unit is in great condition, there is a very light scratch across the face which is hard to see unless at an angle with the right lighting, can’t really see it facing the front. Comes with original box and includes printed manual.
Read this positive review here where Jeff Parks spouts that it offers near state of the art performance:
http://www.positive-feedback.com/Issue45/marsh_p2000t.htm
