MiniDSP or Hypex Monitors?
0 Members and 1 Guest are viewing this topic. Read 2639 times.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
« on: 14 Jan 2016, 02:39 pm »
Some new ribbons arrived and I'm designing a passive 2-way for a customer. While waiting for the passive components I decided to hook up the monitor with my MiniDSP 4x10HD and bi-amp them with a simple DSP crossover (I didn't even take any measurements - just some rough settings).
Scary good.
jtwrace
    • TIPP YouTube Channel
Re: MiniDSP or Hypex Monitors?
« Reply #1 on: 14 Jan 2016, 02:49 pm »
I should send you my Hypex DLCP to play with.
Rick Craig
  • Selah Audio
« Reply #2 on: 14 Jan 2016, 06:21 pm »
Too bad they haven't released the DLCP in a packaged product. They seem to be lagging behind MiniDSP in that regard.
aevans
« Reply #3 on: 14 Jan 2016, 06:44 pm »
Using one plate amp to power both speakers would be the cheapest route. You would still need a passive crossover, but could do baffle step and other filters in dsp to make the speakers very good with just a little tweaking.
