4B SST2 latest version
0 Members and 1 Guest are viewing this topic. Read 2480 times.
alanford69
« on: 13 Jan 2016, 11:42 pm »
Hi all, i am just about to buy a 4B SST2 and I've been told that a couple of years ago there was a relevant update in the transformers. Could you please tell me how i can recognize the items that have such upgrade? Can I recognize them by serial number above ... ?
Thank you very much!
servingko
Re: 4B SST2 latest version
« Reply #1 on: 14 Jan 2016, 02:26 am »
4179 is the serial number with the latest changes but the was no transformer change on the 4, just some input stage changes with mostly capacitors and a change to the soft start circuitry IIRC.
alanford69
« Reply #2 on: 14 Jan 2016, 06:56 am »
Thank you very much, so i just need to ask/verify that the item is of course "c series" and with serial > 4179
I will check today, thanks again.
alanford69
« Reply #3 on: 15 Jan 2016, 09:12 am »
I just ordered my new 4B SST2 giving the above specification, please if there is any other suggestion just forward it to me because I want to be sure to have the latest version.
Given that 4B SST2 will be soon replaced by the Cube series, at least I want to benefit from all the improvements made on this model.
Thanks again for your support.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 15 Jan 2016, 10:48 am »
Order the cubed version.
james
alanford69
« Reply #5 on: 15 Jan 2016, 11:16 am »
james
Hi James, I am in Italy, my reseller asked the local distributor and they replied they have no clue about price and availability so how  can I do that?
« Reply #6 on: 15 Jan 2016, 11:30 am »
Please email me at [email protected] and I will pass on to our export manager.
james
