AV123 ELT525
0 Members and 1 Guest are viewing this topic. Read 2028 times.
Syrah
AV123 ELT525
« on: 13 Jan 2016, 07:19 pm »
Hi All.  I have a pair of these little bookshelf speakers in my third system.  My mind is turned as to how I might tweak them.  If I were to upgrade them, what should I do?  I suspect it's a matter of No Rez, better crossover parts and maybe a bypass cap?
Thanks.
Danny Richie
Re: AV123 ELT525
« Reply #1 on: 13 Jan 2016, 09:49 pm »
Thanks.
There was an early ELT design and a later one. I did the design work on the later models. They were actually really nice drivers. I cap upgrade and a sheet of No Rez will go a long way with these speakers. I'd start there.
Syrah
Re: AV123 ELT525
« Reply #2 on: 14 Jan 2016, 01:15 pm »
Thanks Danny.  I bought these on the AV123 liquidation sale, so I suspect they're the later ones.  think I have some extra no rez from my LS9 build, I'll check.  What cap values does the crossover need?  If I recall, I need to access it via the woofer rather than the back?  Or is it the other way around?
Danny Richie
Re: AV123 ELT525
« Reply #3 on: 14 Jan 2016, 02:34 pm »
You can access the crossover through the woofer hole. I have everything you'll need plus the wiring diagram.
Syrah
Re: AV123 ELT525
« Reply #4 on: 19 Jan 2016, 03:54 pm »
I sent you a PM - but I know you're busy.  Thanks.
Danny Richie
Re: AV123 ELT525
« Reply #5 on: 19 Jan 2016, 04:08 pm »
I didn't get anything from you. Send me an e-mail to [email protected]
