Can someone tell me
0 Members and 1 Guest are viewing this topic. Read 1840 times.
bacobits1
Can someone tell me
« on: 12 Jan 2016, 10:11 pm »
why I can't access 3 sites from here?
innerfidelity.com
A hosting company in El Segundo,CA using Net2Ez as its ISP.
this is the hosting for 3 sites.
www.stereophile.com
www.analogplanet.com
www.audiostream.com
the only sites out of 100 bookmarks I cannot access.
I can access via a proxy server site.
testing with  nwtools.com >>as follows
A connection with the server could not be established
No headers downloaded
ping >> 64.93.76.214
4 sent 32 bits> received 0> 4 timed out> lost 4 (100% loss)
Command promt ping direct>>as follows
Win 10 machines 2, windows 7, 2 machines, Android tablet. All browsers IE, Firefox etc.
All router settings default factory, reset rebooted
browsers set to default and on 4 machines.
What gives here?
Anyone? Anyone else have this problem?
Posted to "Windows Secret" lounge and still no remedy.
simoon
Re: Can someone tell me
« Reply #1 on: 12 Jan 2016, 10:37 pm »
Have you tried to do a tracert?
Your pings tell you that you can't get there. A tracert will tell you where the failure is occurring.
EDIT: I can't ping those addresses either. That would probably mean their servers don't allow ping, to protect from DDoS attacks.
bacobits1
« Reply #2 on: 12 Jan 2016, 10:52 pm »
Simoon thanks!
Here it is>
Microsoft Windows [Version 10.0.10586]
(c) 2015 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>tracert www.stereophile.com
Tracing route to stereophile.com [64.93.76.214]
over a maximum of 30 hops:
  1     1 ms    <1 ms    <1 ms  COPPER-MONKEY [192.168.1.1]
  2     3 ms     2 ms     1 ms  MyRouter.Home [192.168.254.254]
  3     9 ms     9 ms     9 ms  172.16.100.1
  4     9 ms     8 ms     8 ms  h176.34.130.40.static.ip.windstream.net [40.130.34.176]
  5     9 ms     9 ms     9 ms  h130.35.130.40.static.ip.windstream.net [40.130.35.130]
  6    10 ms    11 ms     9 ms  et8-0-0-0.cr02.chrl01-nc.us.windstream.net [40.128.248.160]
  7    14 ms    13 ms    14 ms  h32.59.132.40.static.ip.windstream.net [40.132.59.32]
  8    14 ms    14 ms    14 ms  67.106.215.81.ptr.us.xo.net [67.106.215.81]
  9    66 ms    66 ms    65 ms  207.88.13.54.ptr.us.xo.net [207.88.13.54]
 10    66 ms    79 ms    89 ms  207.88.12.179.ptr.us.xo.net [207.88.12.179]
 11    66 ms    67 ms    75 ms  rcb1.dallas2-tx.us.xo.net [207.88.12.153]
 12    72 ms    67 ms    66 ms  207.88.12.130.ptr.us.xo.net [207.88.12.130]
 13    67 ms    66 ms    66 ms  207.88.14.213.ptr.us.xo.net [207.88.14.213]
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16     *        *        *     Request timed out.
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
 24     *        *        *     Request timed out.
 25     *        *        *     Request timed out.
 26     *        *        *     Request timed out.
 27     *        *        *     Request timed out.
 28     *        *        *     Request timed out.
 29     *        *        *     Request timed out.
 30     *        *        *     Request timed out.
Trace complete.
So what does this tell you?
My end or theirs?
Phil A
« Reply #3 on: 12 Jan 2016, 11:07 pm »
Well I don't see Stereophile's IP Address (unless I missed it) per this - http://stereophile.com.ipaddress.com/
bacobits1
« Reply #4 on: 12 Jan 2016, 11:17 pm »
What don't you see?
rjbond3rd
« Reply #5 on: 13 Jan 2016, 02:27 am »
It's not that unusual for site(s) to be inaccessible due to a routing issue.
Ask your ISP if there is a route between your location and those sites.   (Evidently there isn't, but they need to acknowledge the issue -- they might be aware of it.)  Good luck!
Phil A
« Reply #6 on: 13 Jan 2016, 02:41 am »
What don't you see?
Yes missed it - was focused at looking at the stuff below it.
bacobits1
« Reply #7 on: 13 Jan 2016, 02:47 am »
Thanks!!
I'll see what Windstream has to say.
bacobits1
« Reply #8 on: 21 Jan 2016, 01:44 am »
This has been fixed apparently at their server end. Not Windstream.
