Really enjoying temporary C&C system
0 Members and 1 Guest are viewing this topic. Read 2238 times.
Brad
« on: 10 Jan 2016, 03:26 am »
I bought a Schiit SYS ($59 shipped) to use as a preamp while I'm having some work done on my main gear.
Also using a Schiit Mani phonostage ($129).
Turntable is an AT-LP1240 Direct Drive, with an AT440mla cartridge (bought the cart a few years ago when it sold for about half the current price)
The amp is probably out of C&C territory (Korneff 45).
Speakers are simple Open Baffle, Tang Band W8-1808, in some marine plywood.
Really connecting with the music.  Jack Johnson's In Between Dreams currently playing.
The SYS is a perfect backup component, really just a potentiometer and a 2 way switch. No power plug needed.
The MANI phonostage is clear, quiet, and lets the music flow.  A fantastic bargain, and also made in the U.S.A.
Anyway, thumbs up to Schiit for the nice gear.  Hope everyone is enjoying some favorite tunes tonight.
Brad
Re: Really enjoying temporary C&C system
« Reply #1 on: 10 Jan 2016, 04:23 am »
Moved on to the Once Soundtrack, then Art Pepper Meets the Rhythm Section, next is Burnside on Burnside.
(Apparently I bought some vinyl since the last time I had the turntable going  :lol:  :roll: )
Nick77
« Reply #2 on: 10 Jan 2016, 10:17 am »
Nice! Good sound on the cheap is still possible with careful selection.  :thumb:
« Reply #3 on: 11 Jan 2016, 12:23 pm »
The key to C&C success IME is staying within the comfort zone:  errors should be a omission not co-mission (do no harm, avoid trying to reach for the stars in terms of "excessive" detail, deep bass, etc.).  I've always aimed for non-fatiguing sound that allows me to enjoy the music (even poor recordings).  This is hard to do with better, higher resolution systems.  Have found that focusing on imaging naturally adds resolution without "punishing" levels of detail.  A friend just picked up Elac B6.  Compared to my Ascend Acoustics CBM-170's (the reviewers darling of 2003) they sound more detailed but thinner (reflecting the current trend in sound).  For a baby high-end sound the B6 might win, but for a well rounded system the CBM-170's would be my choice.
If you can't have a well designed room, a high-end headphone system with a C&C in-room system makes the most sense.  At the end of our day at the 2015 Axpona show my buddy and I came across a very small $600 amp/speaker system we fell in love with from Napa Acoustic.  It simply did nothing wrong in a large squarish room and after hundreds of $$$$$ systems, it was a breath of fresh air.  A real C&C winner.
In my living room we have a $99 Logitech UE Smart Radio (wireless clock radio) for background music (I relented and pulled out a leftover of the left overs 3rd system and went smaller/simpler).  It's perfect for what we use it for.  Access to 12,000 online sources plus all my ripped music with up to 6 hours of battery use (within range of your wireless signal).  One decent woofer one decent tweeter that can fill the 10,000 cubic foot space with background music.
persisting1
« Reply #4 on: 11 Jan 2016, 09:48 pm »
JLM,
As often as I see you and countless others recommend these speakers, I have still yet to hear them. Sounds like I have some work ahead of me. These have been on my to-do list for way too long.
Keep up the good work  :thumb:
