PSE HL-1 Hybrid Linestage Outputs and Tube Info Needed
0 Members and 1 Guest are viewing this topic. Read 2152 times.
ACHiPo
My "new" preamp died, so I resuscitated my old PSE HL-1 line stage. I didn't have subwoofers when I used it several years ago, and I'd like to use its secondary single-ended outputs to drive my stereo subs, but I only get signal out of the RCA outs when the balanced outs are disconnected.
I know I need new tubes (they're on order), and I'm wondering if that will allow both outputs to run at the same time? I've found a couple threads on the web that suggest both outputs should work at the same time, but information on these preamps is scarce.
Also, I saw a couple threads online about tube rolling, but I'm also looking for input on preferences for 6DJ8-type tubes (I have pairs of Valvos and Matsushitas on order).
AC
JakeJ
Re: PSE HL-1 Hybrid Linestage Outputs and Tube Info Needed
« Reply #1 on: 9 Jan 2016, 03:27 am »
I would suggest to you that the threads you read are giving you false information.  Most all the amps and preamps I have known or experienced that had both balanced and single-ended one could not use both simultaneously.  Inputs or outputs.  Hopefully one of the more learned will give us technical description of why and what the differences are?
BTW, Did you have to use the paddles to bring life back into the PSE?  :wink:
ACHiPo
« Reply #2 on: 15 Jan 2016, 03:16 am »
I just saw this.  Sorry for the belated reply.
The PSE is making music, but I'm pretty disappointed at this point.
I ordered a matched pair of Valvo 7DJ8s from Brent Jesse.  I opened it up, took some Deoxit D100 and F5 to the pots and switches, cleaned the tube sockets, and replaced the tubes.  While the new tubes eliminated the crackling I was getting, the bass is just as bloated and the top end is just as rolled off as before.  While I had the top off I looked around and all the caps looked ok--no bulging, corrosion, or signs of leakage.  Two bypass caps had what looked like cellophane wrapping cracking and peeling a bit, but it just looked cosmetic.  I did notice that it is a very well constructed piece of gear, and has aged well.
I'm about 10 minutes in with the new tubes, and the volume is still very low (need to turn the volume to the max to get to ~80 dB, which is louder than I usually listen, but not as loud as I sometimes listen.  Last week when I first reinstalled the PSE the volume was also very low, but seemed to get progressively louder over a few days, so maybe it's a combination of caps charging and tubes warming up?
There is some midrange magic, although so far I liked the sound and musicality of the Oppo straight into the M60s much better.
ACHiPo
« Reply #3 on: 15 Jan 2016, 03:20 am »
Oh and the RCA outputs still don't work.  Looks like there's a new preamp for me in my future.  Now, to just decide between a Vinnie Rossi Lio (which can only handle one pair of balanced inputs--a definite strike against it) or the Parasound JC2, which is the preamp that was driving the Kef 207/2s when I bought them.
