Vegas CES Show 2016
0 Members and 1 Guest are viewing this topic. Read 14404 times.
Rod_S
Re: Vegas CES Show 2016
« Reply #20 on: 10 Jan 2016, 12:49 pm »
Very neat, given it's age I kinda thought you would shy away from a hardware update. This continues to show Bryston's commitment to their products, very nice.
Soldeed
« Reply #21 on: 10 Jan 2016, 02:32 pm »
So what's up next in the pipeline James? I know you had mentioned not to long ago about looking into getting the SP3 to accept above 44.1/16 via the USB. Is that still being looked into? I assume it would never accept DSD?? That would probably be a more substantial hardware upgrade and I suspect not worth it and would be something that would make more sense in the next platform when I suspect Atmos, dts:X and possibly Auro may make an appearance in a limited 16 channel or less configuration.
My WISHLIST
Bryston SP4 Dirac Live Atmos DTS X Auro 3D   9.2.6  all for 10K MSRP....I know dream on!!
Soldeed
« Reply #22 on: 10 Jan 2016, 02:34 pm »
James
Was the CES room not big enough to properly set up the Model T's?
Or was your main focus showing  the Mini T's
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #23 on: 10 Jan 2016, 02:58 pm »
James
Yes the main focus was on the Mini T's.
The Model T's sounded terrific in that room but I find at shows if you set up a small speaker like the Mini T's peoples expectation of how a small speaker is capable of sounding is radically changed as a result of listening to a Mini T.
The response we get is priceless  :thumb:  They are really surprised at how big and open they sound and the expanse of the soundstage - they really do disappear. Also the superb dynamics the Bryston speakers have is very surprising to some - very horn like dynamics without typical shouting horn like colouration available in a traditional box speaker.  And of course we continually get asked -"where is the subwoofer hidden".  Its a great demo even if I do say so my self.  :thumb:
james
Soldeed
« Reply #24 on: 10 Jan 2016, 03:46 pm »
You have made my decision even tougher to decide which speakers to purchase.
What is the Canadian MSRP on the Middle T and Mini T in Black Ash?
Model T is at the top of the list but with all the praise of it's siblings I am
beginning to second guess myself.
« Reply #25 on: 10 Jan 2016, 03:51 pm »
Hi
The Model T is still the king but I tell people there is no better/best approach with our speakers.
Think of it like a car engine - do you want a 4 cylinder or a 6 or an 8 cylinder - the quality is identical.  It just depends on what volume levels you want at low distortion based on room size and  listening taste.
james
scirica
« Reply #26 on: 10 Jan 2016, 04:57 pm »
You know my vote!!
Jimmy71
« Reply #27 on: 10 Jan 2016, 04:58 pm »
Hi
james
Hi James when will the sst3 start production,and will the upgrades from sst2 to sst3 start the same day with the production?
« Reply #28 on: 10 Jan 2016, 05:18 pm »
Hi
It will be a couple of months on the upgrades as there is a lot to do and so,e mechanical issues need to be worked out.
james
« Reply #29 on: 11 Jan 2016, 04:20 pm »
SUBJECT: Bryston Demo CES Vegas 2016
January 2016
Vegas CES - 2016
HERE ARE SOME ADDITIONAL PHOTOS FROM THE BRYSTON ROOM TO SUPPLEMENT JIM'S VIDEO.
HAD A CHANCE TO TAKE AN EXTENDED LISTEN TO THE BRYSTON MINI T SPEAKERS (FIRST PHOTO) WHILE CHATTING WITH JAMES TANNER.
HE DISCUSSED HOW, WHEN THEY DESIGNED THE MINI T, BRYSTON WANTED TO ACHIEVE A WIDE DISPERSION DESIGN SO THAT THE SPEAKERS WOULD SOUND VERY GOOD WHEN LISTENING OFF-AXIS AS WELL AS ON-AXIS.
TO MY EARS, THE SPEAKERS SOUNDED CLEAN AND EFFORTLESS AND GAVE AN HONEST AND DYNAMIC MUSICAL DELIVERY.
MISSION ACCOMPLISHED JAMES!
CARLO LO RASO
alexone
« Reply #30 on: 11 Jan 2016, 06:23 pm »
Hi Al
Yes the demo system is the BDP-2 with BDA3 into the BP26 then out to new 7B Cubed amps and driving Mini T's - all plugged into a BIT 20
james
James,
the 7, 14 and 28 have the ''BIT technology'' inside, correct?? so the reason why i'm asking is if it makes sense to use a BIT for any of these amplifiers... :scratch:
al.
« Reply #31 on: 11 Jan 2016, 06:59 pm »
James,
al.
Correct - other than surge protection no real advantage.
james
« Reply #33 on: 12 Jan 2016, 07:59 pm »
Rod_S
« Reply #34 on: 13 Jan 2016, 12:58 pm »
Getting back to the SP3 USB update, so once this becomes available I guess there would be no need for a BDA to get greater than 44.1/16 into the SP3 from a BDP unless you run in bypass to take advantage of the better external DAC or have greater than 192/24 files? With the BDA3's USB input capable of 384/32 why not use that chip or one similar or are you not actually changing the USB chip in the SP3 rather just unlocking the full potential of the existing chip?
Will the USB input continue to be stereo only? It would be great if it's multichannel.
« Reply #35 on: 13 Jan 2016, 01:20 pm »
Hi Rod
Stereo only and yes the USB section will be the same as the USB unit in the BDA-3 - the DACs in the SP3 though will remain the same.
james
Rod_S
« Reply #36 on: 13 Jan 2016, 01:44 pm »
Hi Rod
james
Ah interesting about the USB going to be the same, so that would mean then one can input the max 384/32 files (HDTracks offers some 352/24 content) into the SP3 but in reality you'll be limited to 192/24 due to the SP3's DAC's?
Rod_S
« Reply #37 on: 13 Jan 2016, 01:47 pm »
Oh, I forgot to ask, how is DSD going to be handled then if the DAC's remain the same, I'm assuming they are not DSD capable DAC's but maybe they are.
« Reply #38 on: 13 Jan 2016, 02:12 pm »
Yes the DACs are limited to 192/24 in the SP3.
james
« Reply #39 on: 13 Jan 2016, 02:14 pm »
Not sure if DSD will be possible still looking at that because it may need a hardware change or DSD 64 only.
james
