This Just in
0 Members and 1 Guest are viewing this topic. Read 2721 times.
Mag
This Just in
« on: 31 Dec 2015, 07:12 pm »
Last night I spent 3 hours backing up my 80 gigs of personal re-masters from 3 USB Flash Drives. To the USB Corsair Voyager 128 gig Flash Drive, for use with my BDP-1.
Initial impressions is the sound is much warmer. Like switching from my Sony BDP-S185 to my Sony NS9100ES. Maybe after a weekend of listening it'll become my main drive.
Who knew Flash drives can be an audio upgrade as well?
Mag
Re: This Just in
« Reply #1 on: 5 Jan 2016, 01:52 am »
Just an update on the USB Corsair Voyager Flash drive.
I liked the sound so much I bought one more, which should cover future needs for the BDP-1.
Don't have a good reason for the warm sound with the BDP-1 other than just made better. Perhaps there's a break in period and the sound will change again.
Should I dare attempt to describe 'warm sound' when I can find no consensus on what audiophiles mean by the term 'warm'.
Well, with my recordings there's no loss in detail, in fact there's a little more detail. The bass  sounds a little more powerful but darker than the typical Flash drive. The music is natural sounding and more inviting to listen to.
The downside is the absence of the neutral energetic sound of other Flash drives I've used, which may be preferred with some music. :smoke:
yioryos
Re: This Just in
« Reply #2 on: 5 Jan 2016, 09:45 pm »
Hi Mag
2 questions please ,what is the largest available capacity for the Corsair Voyager? how much did it cost you for the 128g you using? I was thinking maybe I could split my 1Tb music library into 3 or 4 parts and perhaps loaded on these.
George
Tympani
Re: This Just in
« Reply #3 on: 5 Jan 2016, 11:24 pm »
I think we are just scratching the surface on the impact of different storage media, digital connections and power supplies on the sound of this new medium. Hi-rez digital files, played through highly resolving systems, are allowing the "active listener" to appreciate fairly significant differences between these support devices that traditionally had been considered inconsequential. The differences between different flash drives, as noted here, is a prime example. Who knows what makes the Corsair drive sound "warmer" than your previous drives. Why does my SSD drive sound different than my external WD spin drive? Intuitively, one would think that "noise", in the vaguest but most ubiquitous sense, is at play. Solid state drives generate electronic noise whereas spin discs generate mechanical noise. Is one worse than the other in destroying those micro-acoustical cues we associate with high fidelity?
I read Karl Schuster's somewhat vexing recent review in TAS on the BDP-2 with IAD last month. After singing the praises of the player, he stated that the only storage interface that sounded really good was a now-discontinued hard drive (the Seagate GoFlex Free Agent Portable), all contemporary drives that he tried sounded "thin" or "flat" or "constricted". What's going on?
I really doubt we are hearing the full quality of our hi-rez files. It would be fun to identify flash drives/HDD that cater to audiophile concerns and not simply boasting super fast write and read speeds. There's so many choices out there, its a crap-shot. Heck, I see a good marketing opportunity!
Mag
Re: This Just in
« Reply #4 on: 6 Jan 2016, 12:31 am »
Hi Mag
George
I see amazon.ca has Corsair Voyager 512 GB for $460, 256 GB $130 and the 128 GB for $70. But I'm only endorsing the 'Corsair Voyager Slider 128 GB usb 3.0' because I haven't tried the other ones, I don't know if the components that make up the flash drive are the same. It has a 5 year warranty if you keep the sticker on back of package.
I paid $62.99 cdn. The above prices are cdn dollar as well. :smoke:
Mag
Re: This Just in
« Reply #5 on: 6 Jan 2016, 12:48 am »
I haven't heard a hi-rez file yet. I can tell you though that you haven't yet heard what 44.1/16 bit recordings are capable of. I submitted my idea to Bryston, hopefully they can make it practical to use. :smoke:
