Audio/Video Gear and Systems
The HiRez Music Circle
ted_b
Auralic Aries ?
Auralic Aries ?
0 Members and 1 Guest are viewing this topic. Read 1984 times.
orientalexpress
Auralic Aries ?
30 Dec 2015, 12:43 am »
Hi,I have Sacd iso file on external HD,for some reason the Aries would not recognize the files when it scan.
,did I set up something wrong? Thanks
Lap
jarcher
Industry Participant
It Just Sounds Right
Re: Auralic Aries ?
30 Dec 2015, 03:44 am »
Aries wil recognize DSF and DFF SACD files but not ISO. You'll need to convert the ISO to DSF or DFF. Believe there is software that can do that - google search will help or else I'm sure other's here will chime in.
ted_b
Facilitator
"we're all bozos on this bus" F.T.
Re: Auralic Aries ?
Reply #2 on:
30 Dec 2015, 03:54 am »
The Auralic Aries never purported itself to read/playback SACD ISOs. JRIver can, but not many other players.
Simply use Audio Circle partner Sonore's free ISO2DSD (use the DSF setting, dual setting for 2 channel DSD files) extractor GUI to extract DSF files from your ISO.
http://www.audiocircle.com/index.php?topic=129913.msg1373112#msg1373112
ted_b
Auralic Aries ?
