SOLD: Parasound A21 - as new condition $1395
0 Members and 1 Guest are viewing this topic. Read 1097 times.
blownrx7
« on: 26 Dec 2015, 09:50 pm »
For sale is my as-new condition Parasound A21. It is approximately 4 yrs old and has seen VERY light use.
The amp comes with the original double-box and manual as well as a power cord.
Product Description
Halo A21 Two-Channel Amplifier
Continuous power output (20 Hz - 20 kHz): 250 watts RMS x 2 at 8 ohms, 400 watts RMS x 2 at 4 ohms, 750 watts RMS x 1 (bridged mono mode) at 8 ohms
Current capacity: 60 amperes peak per channel
Power bandwidth: 5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total harmonic distortion: < 0.2 % at full power
IM distortion: < 0.04 %
Slew rate: >130 V / µsecond
Dynamic headroom: > 1.5 dB
Interchannel crosstalk: > 80 dB at 1 kHz; > 63 dB at 20 kHz
Input sensitivity: 1 V for 28.28 V, THX Reference Level
Input impedance: 33 k ohm unbalanced; 66 k ohm balanced
S/N ratio: > 112 dB, input shorted, IHF A-weighted
Damping factor: > 1100 at 20 Hz
Voltage: 110V – 120V
Dimensions: 17.25" wide, 7.625" high (7" without feet), 19.12" deep
Net weight: 60 lbs.
Price is $1395 + actual shipping charges. Paypal gift or add 3.5%.
Check my perfect feedback here, on US Audiomart, Audio Circle and Audiogon (username at Audiogon is m297904).
I am located in CT 06070 so you can calculate shipping using UPS calculator. The packed unit weighs appx. 75 lbs.
Local pickup is welcome!
« Last Edit: 28 Dec 2015, 07:53 pm by blownrx7 »
blownrx7
Re: FS: Parasound A21 - as new condition $1395
« Reply #1 on: 28 Dec 2015, 07:53 pm »
SOLD. Local sale.
Thanks, Scott!
