Tempest pre with 2 turntables connected at the same time?
0 Members and 1 Guest are viewing this topic. Read 1317 times.
Will
This could be a Klaus question, but I'll throw it to the forum...
The Tempest has 2 pairs of RCA inputs for turntables, one for MC and one for MM.  Is it possible to keep two turntables connected, and merely use the toggle switch to select which TT is being used at that moment?  Or will having 2 TTs connected degrade the signals of both?
Thanks for your comments!
Will
paul79
Re: Tempest pre with 2 turntables connected at the same time?
« Reply #1 on: 18 Dec 2015, 11:55 pm »
Well hell no! Hook em both up... Should be just fine. That switch takes the other out of the equation when not selected.
Will
« Reply #2 on: 19 Dec 2015, 06:56 pm »
Thank you very much, Paul79!
