Tube amps for electrostatic speakers
0 Members and 1 Guest are viewing this topic. Read 6419 times.
maplegrovemusic
  • Please Be kind to your ears .... Treat your room
« on: 18 Dec 2015, 07:10 am »
What specs should one look for when choosing tube amps for electrostats ? I own King Sound King v1 speakers . On king sounds website they sell a 80 watt tube amps to accompany the king model . Now I assume I cannot just get any old 80 watt tube amp to drive my speakers . There must be something I need to try and duplicate . Their amp is out of my price range and I am not even aware if there is a u.s. distributor for the king amps . Crazy spendy anyways . My budget on the used market is around $2500 . Solid state class A I know can drive them . 60 watts will do it in my room . Never owned any tube amps so have no idea what to look for . Are class A tube amps similar to solid state class A . Thanks for reading and all comments welcome .
sfox7076
Re: Tube amps for electrostatic speakers
« Reply #1 on: 18 Dec 2015, 03:06 pm »
You won't find anything close to a 60 watt class A tube amp unless you use pretty big pentodes in a Class A push-pull (KT66, KT88, KT120 or KT150) or a bunch of tubes in parallel.  I think KT120 or KT150 will be your only options here if you want Class A because you will need massive plate dissipation. Not a ton of cheaper amps for you to run here. Are you opposed to AB operation in a tube amp?
maplegrovemusic
« Reply #2 on: 18 Dec 2015, 03:39 pm »
Hello , I am not opposed to ab . So tube class a is different than solid state. Just needs to be able to power a electrostatic . dips below 2 ohs in treble .
Mike B.
« Reply #3 on: 18 Dec 2015, 05:04 pm »
The Quicksilver Silver Mono amps from the 1990's had transformers with 8, 4 and 2 ohm outs. I assume for ribbon full range speakers.
SwamisCat
« Reply #4 on: 18 Dec 2015, 05:53 pm »
PS Audio's new BHK amps have tube input and solid state output. I am currently testing the 300 W  monoblocks with Maggies and they sound sensational -- extremely relaxed and smooth, but with plenty of bass. Expensive though at $15 K.
a.wayne
« Reply #5 on: 18 Dec 2015, 06:16 pm »
Hello Swamis Cat,
Very interested in hearing your comments about the new BHK amplifier ....
pehare
« Reply #6 on: 18 Dec 2015, 07:25 pm »
Music Reference RM200 MkI or II would be perfect IMO.  Power goes up as impedance goes down.
maplegrovemusic
« Reply #7 on: 18 Dec 2015, 08:39 pm »
pehare : Great suggestion . Forgot about them ! Like that those were the Stereophile reviewers reference for over ten years.
twitch54
« Reply #8 on: 18 Dec 2015, 09:38 pm »
it's not just the impedance drop in the treble region one needs to be concerned with, electrostatics present a very 'capacitive' load to ones amp(s) so in choosing amplification ……….. current, stability and wide bandwidth all play a role. The biggest problem with lesser tube amps is stable / wide bandwidth issue and how it effects the treble roll-off.
Also keep in mind when selecting an amp you should be aware of your speaker cable specs so as to minimize capacitance per foot.
FWIW, I drive my stats (M/L Hybrid 'Spires') with a pair of Rogue M-180 monoblocks …………. couldn't be happier !
maplegrovemusic
« Reply #9 on: 19 Dec 2015, 01:02 am »
Rogue is a brand i just assumed would not work because i seen their ratings only into 8 and 4 ohms . Somehow King Sound has designed a 80 watt amp to pair with their speakers ?
Minn Mark
« Reply #10 on: 19 Dec 2015, 04:30 pm »
Look at Audio by VanAlstine 400R or 600R. Best of both worlds, tube front end and SS reliable power into low impedance loads.  I use an all SS AVA amp with Maggie 3.6R's bi-wired with excellent results.  Very revealing, but not harsh unless the recording is a poor one.  Wide, deep soundstage. More then enough power (225W@ 8ohms).
Best regards,
Mark
maplegrovemusic
« Reply #11 on: 19 Dec 2015, 09:25 pm »
Best regards,
Mark
Looking for straight tubes for now . Already have a satisfactory solid state amp . I just purchased the Zero former from Paul Speltz . Hopes this makes whatever tube amp i get work better ? we shall see . Anyone here use one of those ?
Freo-1
« Reply #12 on: 19 Dec 2015, 09:44 pm »
VTL made some higher powered tube amps that would fit the bill.  I had Acoustat Spectra 33's for YEARS.  They needed watts, but watts with sufficient current.  I used a Audio Research D115II with them, and they worked well together.
SteveFord
« Reply #13 on: 20 Dec 2015, 12:02 pm »
I can't speak for King Sound speakers but I'm very happy with VTLs paired up with Magnepans.
I think they'd have enough power to work out well for you.
louie3
« Reply #14 on: 21 Dec 2015, 01:37 pm »
I used the Zero Autoformers with my tube amps and Maggies( hotrod SMGc..."homegunned") to good effect.   When I bought my Quad 63s I sold the autoformers too quickly, big mistake I suspect.
Very audible improvement with the tube amps and Maggies.   Wish I had kept them a little longer for the Quads.
twitch54
« Reply #15 on: 24 Jan 2016, 01:44 pm »
Never assume …………… Rogue makes incredible products and at price points that is tough to beat. My M-180 mono blocks easily perform well beyond their price. They do a superb job on my Logan Spires and yes I'm well aware they are a 'hybrid' electrostatic speaker.
